I was using an Arduino Uno R3 for my project, and I decided to move my project on my Arduino Mega. The example code "sensorapi" works perfectly with the R3, but the same exact code will not work on the Arduino Mega.
It's being hooked up to Analog4/5 on both arduinos--as per adafruit instruction.
I don't understand why this is happening, and I need a solution :(
Can someone please help?
(Yes, I have verified with other projects that the arduino works)
TSL2561 doesn't work with Arudino Mega
- Franklin97355
Re: TSL2561 doesn't work with Arudino Mega
The TSL2561 is an i2c device but the i2c (TWI) pins on a mega are not on the same pins as on a Uno. http://www.arduino.cc/en/Main/arduinoBoardMega2560It's being hooked up to Analog4/5 on both arduinos
TWI: 20 (SDA) and 21 (SCL). Support TWI communication using the Wire library. Note that these pins are not in the same location as the TWI pins on the Duemilanove or Diecimila.
