Oh ibuki apologies, I mixed up the name of the package. It's the 'python3-pip' package and not 'python-pip3'. Confusingly once it's installed you'll use the 'pip3' command to run it... but the package is called 'python3-pip'. Sorry try again but with 'sudo apt-get install python3-pip'.
Thanks for grabbing the error message micolli9--hrm 'invalid_grant' isn't something I've seen, but the one thread I could find on it (here: https://github.com/google/oauth2client/issues/193) seems to indicate it could be a problem with an invalid or older credential file. Just to rule out the credentials being out of date, if you grab a new json file for credentials (from google's dev console) does it work? Oh and you're right you can ignore step 6--the spreadsheet example code will load the JSON file and get the credentials inside it. If you do the steps before that and download a new JSON file let's see if that helps get the spreadsheet authentication working. Thanks!
DHT temp sensor login issues
- isuga
Re: DHT temp sensor login issues
It looks like "sudo apt-get install python3-pip" worked. Seemed to download and install package. No errors.
However, when I tried "sudo pip3 install gspread", it says "sudo: pip3: command not found". Tried it after reboot and still got same message.
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
python3-dev python3-pkg-resources python3-setuptools
The following NEW packages will be installed:
python3-dev python3-pip python3-pkg-resources python3-setuptools
0 upgraded, 4 newly installed, 0 to remove and 37 not upgraded.
Need to get 478 kB of archives.
After this operation, 1,510 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python3-dev all 3.2.3-6 [1,062 B]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python3-pkg-resources all 0.6.24-1 [33.9 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python3-setuptools all 0.6.24-1 [363 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python3-pip all 1.1-3 [79.7 kB]
Fetched 478 kB in 3s (157 kB/s)
Selecting previously unselected package python3-dev.
(Reading database ... 79779 files and directories currently installed.)
Unpacking python3-dev (from .../python3-dev_3.2.3-6_all.deb) ...
Selecting previously unselected package python3-pkg-resources.
Unpacking python3-pkg-resources (from .../python3-pkg-resources_0.6.24-1_all.deb) ...
Selecting previously unselected package python3-setuptools.
Unpacking python3-setuptools (from .../python3-setuptools_0.6.24-1_all.deb) ...
Selecting previously unselected package python3-pip.
Unpacking python3-pip (from .../python3-pip_1.1-3_all.deb) ...
Processing triggers for man-db ...
Setting up python3-dev (3.2.3-6) ...
Setting up python3-pkg-resources (0.6.24-1) ...
Setting up python3-setuptools (0.6.24-1) ...
Setting up python3-pip (1.1-3) ...
- isuga
I FINALLY got it to work.
I ended up installing Python 3.4.3 which wasn't as bad as I thought it would be. Oauth2client does not support Python 3.2 so you have to upgrade to 3.3 or higher if you want to use Python 3.
I used instruction on http://sowingseasons.com/blog/building- ... -pi-2.html to install Python 3.4.3.
Then I used "sudo pip3 install gspread oauth2client PyOpenSSL" to install everything into the Python 3 environment.
Then I found out that the strings are defined a little differently in Python 3 so I had to use the instructions on
http://stackoverflow.com/questions/2995 ... -for-oauth
to solve that little problem.
It now seems to work OK in my little test program.
I hope this works for people who are interested in doing this with Python 3. I will note that I had my test program working with Python 2 FIRST. And that took me some trial and error. So the steps above may depend on some things that I had already done to get it working for Python 2.
Addendum:
One last thing you have to do is :
sudo pip3 install RPi.GPIO
I have a project the monitors the temp for a freezer w/ temp sensitive supplies. It monitors the temp and a door sensor. It has an LCD display which shows me the temp status. And it e-mails/texts me w/ alerts for out of range temps or if the door is open for too long. It also logs the temps into Google Sheets.
And now.... it's all working again!
Addendum:
- tdicola
Oh nice, thanks for posting all the steps to work with python 3--that will definitely help folks in the future. Good luck with the project!
- foxfaisal
Good day ladies and gentlemen,
I am super duper newbie in here. I would like to start getting the OAuth2 credentials as instructed in the following page:
https://learn.adafruit.com/dht-humidity ... cs-updated
The page above redirect me to the following page:
http://gspread.readthedocs.io/en/latest/oauth2.html
I did step 1 until step 3 in the link above. I'm not sure whether what I did is correct or not, but but I already got the .json file. Please let me know if anyone here would like to check the content of the json file.
Step 4 in the link above is missing.
Step 5 told me to install oauth2client and PyOpenSSL using the following command:
pip install --upgrade oauth2client #install oauth2client
pip install PyOpenSSL # install PyOpenSSL
Step 6 says that "Now you can read this file, and use the data when constructing your credentials:". Now I have no idea what while does it refers to. Does anyone in here knows what file is it? Please advice.
Merry Christmas and happy holiday. Thank you.
then
then
- foxfaisal
Dear ladies and gentlemen,
Regarding my posing above, I would like to inform you that mine is works. My Pi 3 writes data to my google drive every 60 second. I am a beginner and don't know in detail some of the things that I did, but it works :-p
I have requirement to read and store data from more than 1 sensors, but so far I have no idea right now. Will go through the instructions in detail again, then inform all of you about my progress.
Thank you very much.
