I'm looking for an interface for get the change of sensor's electrical resistance and increment results in table.
Actualy, I would like to be able to plot the signal from my sensor through Excel for exemple. For get data I imagined to use USB connexion, save data on SD card or why not use GPS signal.
Could you help me or maybe easily show something that certainly already exciste.
interface for sensor
Re: interface for sensor
There are many types of resistive sensors. You didn't mention what type you are using. The basic principles for measurement with resistive sensors are pretty much the same:
https://learn.adafruit.com/force-sensitive-resistor-fsr
https://learn.adafruit.com/thermistor
https://learn.adafruit.com/photocells
- Noan
Thank you for your answer.
the sensor that I will used is this one
http://www.figaro.co.jp/en/product/entry/tgs2600.html
I also thought to use this module with
http://www.figaro.co.jp/en/product/entry/am-1-2600.html
Those are not devices that we sell or support. You should be able to get technical assistance from the manufacturer or vendor of these devices.
