Hi All,
Does anyone know what the power of the board is including the regulator? The documentation only specs the display itself. Also, does anyone have experience with figuring out the refresh power per Mhz used...Again, the spec only shows typical power at 1Mhz...
Thanks,
Jose
Sharp Memory LCD Breakout Power
Re: Sharp Memory LCD Breakout Power
The total power consumption for all the other chips on the board will be a few microamps.
Given that all the currents in the circuit are small, your best bet will be to hook it up to something like a 100mAh LiPo and measure the discharge rate over several days:
https://www.adafruit.com/products/1570
- josep01972
Thank you.
