Good morning,
I recent receive the material that i order from you, after trying to put the breakout board TMP007 to work with no result i decided to do a different test.
The test was to connect several board in the same I2C bus, i connect one Arduino UNO, the display that a order with the temperature sensor and the temperature sensor, and put to run on the Arduino a software that try to find the different address in the I2C bus. The software only found one address, the address of the display as you can see in the image bellow.
#779425-1995963117
TMP007
- adafruit_support_rick
Re: TMP007
Please post clear, detailed pictures of both sides of the modules, showing your soldering and wiring
