Hello to all!
I have this project where i have to measure the tilt of a metal plate from an initial attitude, to be able to calculate angles in both plane axis.
See it as a metal tabletop standing on uneven ground.. I need to find out the amount of difference from absolutely level.
I have four motors in the corners to level out any differences.
But i need to know with how much.
I was looking at the 10DOF, am not sure it will "hold zero" if the power is cut.
And also, the magnetometer, can i "recalculate" to compensate for the induced magnetism in the plate itself?
Trying to make a plane surface level.
Re: Trying to make a plane surface level.
You don't need a 10DOF IMU to detect level. A 3-axis accelerometer is sufficient - and not influenced by any magnetic effects of your rig. To achieve level, you just need to zero out both X and Y axis readings. The Z-axis should then read exactly 1G.I was looking at the 10DOF
That is a function of your drive system. Most steppers do have some magnetic 'cogging' that will resist turning when un-powered. If there is sufficient mechanical advantage in the gear-train and linkage, it will hold position.not sure it will "hold zero" if the power is cut.
- rikjoh
If i get this straight...
(as a clarification, the plane is the hull of a scale "BANNED tank".)
If i use the three axis module, i can determine the attitude of the hull in
regards to "zero" even if the system is powered down, and the model is
moved to another location with a slight incline and side slope...?
And thus being able able to accurately calculate the gun-barrels aim point?
We are starting up a laser target game. And i dont want to have to re-calibrate
the sensors every time its transported to a new arena..
Yes. The gravitational force vector is always perpendicular to the level plane. If the sensor is level, the gravitational force vector will be aligned with the Z axis. If the sensor is tilted from level, some part of that force will be detected in the X and/or Y axis. If you detect a tilt, your leveling motors can compensate until the X and Y both zero out.If i use the three axis module, i can determine the attitude of the hull in
- rikjoh
Thank you!
Just what i needed to know.
