Hi everybody,
all of a sudden, the DONE indication LED and the CHARGE LED on my solar charger (https://www.adafruit.com/product/390) are lit all the time, even when
no rechargeable battery is plugged in. As soon as I plug in the USB cable, all the LEDs light up and stay that way when I connect a battery.
Is it broken or does it still charge, with only the LEDs not working as the should?
Best Regards
Dom
Solar Charger - still working or broken
- Franklin97355
Re: Solar Charger - still working or broken
What is the output on the battery pins when you have it connected to a partially discharged battery?
- MrCurbsurfer
Hi Franklin,
sorry for the late reply. I was just too busy with putting all the stuff together and soldering for the last days.
The charger is working fine after all. All the batteries I was working my test circuits with were fully charged, or almost fully charged. Since I have almost no experience
in electronics, I was expecting that the power was drained much faster from the batteries, even though I was only powering my build for a couple of seconds from time to time.
Today, one of them went out of power, my led strip went off. I plugged it to the charger, the green led didn't light up, only the yellow one. After ten minutes of charging, there was enough power to light the strip up again. So it's working fine =)
Best
Dom
Best
Dom
