I am working with a new TMP007 and have encountered a couple of problems. These occur whether I'm using the sample code or my own project. The controller is an Adafruit HUZZAH ESP8266.
In the sample code, the call to tmp007.begin() always returns false. As an experiment, I tried ignoring the return value and found that I get reasonable readings from readDieTempC but always get nan from readObjTempC regardless of what is within the sensor's field of view.
I have tried with and without a call to Wire.begin(4, 5) prior to calling begin() in the TMP007 library.
The TMP007 board is wired to the HUZZAH like so:
Vcc -> V+
Gnd -> Gnd
SDA -> #4
SCL -> #5
Alert -> No connection (NC)
AD1 -> NC
AD0 -> NC
Power is from an Adafruit FTDI serial cable connected to my computer's USB. IDE is Arduino 1.6.5.
Thanks for taking a look at this.
TMP007 problem with begin() and reading object temp
- rabatecola
- adafruit_support_rick
Re: TMP007 problem with begin() and reading object temp
begin will only return false if the device ID it reads from the chip is not 0x78. You can enable debugging to print out the device ID it is getting. Uncomment the symbol in Adafruit_TMP007.h
// uncomment for debugging!
#define TMP007_DEBUG 1
