Connecting Stepper motor to Motor Shield
Phil_Rounds
Post by Phil_Rounds »
I've only found directions for connecting your stepper motor to the motor shield (based on your wire colors. I couldn't find a wiring diagram). I'm connecting a stepper with the following connection diagram:
Note: I'm using the leftmost, -LW4 model
Am I right that I connect BLK/ORG (in no particular order) to M3, skip one, then connect RED/YEL to M4?
Thanks in advance,
Phil
Re: Connecting Stepper motor to Motor Shield
That is correct.
Phil_Rounds
Thanks for the quick reply.
When I wired it up and tried to run it, it made a little noise and the power light on the card went out for about 1 sec. I was powering the arduino through the motor shield input ( 12V, 1A), so I removed the jumper, powered the arduino from the pc. Then when I tried to run it, it started a little, then the power light on the card went out.
I can only assume that I'm drawing too much current, and the motor shield is powering down to protect itself.
I'm using the a motor I discussed here before viewtopic.php?f=31&t=63772 (scroll almost to the bottom, then find the highlighted product in the table), and we agreed that it would only draw .85 amps at 12v, so I should be ok, no?
Phil_Rounds
Never mind, I'm pretty sure that the fact they shipped me a 3V/3A model rather than the 10.2V/.85A model I ordered may go a long way to explaining what I'm seeing.
Phil
If you measure the resistance of the coils, you can tell which motor the sent. If you are powering with 12v, you want a coil resistance of 10 ohms or more to avoid overloading the shield. To stay under 1A total current draw (for both coils), you need a coil resistance of 24 ohms or more.
