no green light
no green light
Postby stevematt21 » Mon Dec 17, 2012 6:45 pm
Hello ! i have purchased a kit v2.0 and i built it today, tried to use it on my new mac mini, no green light. I read that it has a problem with usb 3.0 ports, so i tried to use it on my dell laptop no luck...
i tested my solder connections with a ohm meter all connections work just fine
stevematt21
Re: no green light
Postby adafruit_support_bill » Tue Dec 18, 2012 6:18 am
Post photos of the front & back of the board and we will check the assembly.
Re: no green light
Postby stevematt21 » Tue Dec 18, 2012 10:47 am
here it is
stevematt21
Re: no green light
Postby adafruit_support_bill » Tue Dec 18, 2012 11:53 am
You have many joints that are not completely soldered. Testing them with a meter is not sufficient. Review the soldering guide and re-flow all the joints and add solder as needed.
http://learn.adafruit.com/adafruit-guid ... -soldering
http://learn.adafruit.com/adafruit-guid ... n-problems
Re: no green light
Postby stevematt21 » Tue Dec 18, 2012 6:12 pm
success! A found new hardware came up now what do i do?
stevematt21
Re: no green light
Postby stevematt21 » Tue Dec 18, 2012 7:15 pm
Ok found out how to install it, i put the blank atmega 168 in the audrino uno plug the 6 pin cable to the uno from the usbtiny and burn the bootloader this is the error message i get
stevematt21
Re: no green light
Postby adafruit_support_bill » Wed Dec 19, 2012 7:12 am
Post a photo showing all your connections.
Return to USBtinyISP
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
