Usbtiny version 2 on Vista not working
USB AVR Programmer and SPI interface. Adafruit's USBtinyISP.
Postby Choba » Wed Oct 14, 2009 11:28 am
Hello, I have a problem. The green light is burning, but Vista (64bit) gives an error during installing, Code 39.
I used v1.12 of driver. I also tried to remove the 'check signed driver' thing, with a cmd command. I have USBtinyISP v2.0.
In Dutch:
Kan het apparaatstuurprogramma voor dit apparaat niet in het geheugen laden. Mogelijk is het stuurprogramma beschadigd of het ontbreekt. (Code 39)
Okay, so I still hooked a target board on it, with the attiny13 and a led (with resistor). I also found code for flashing led. But I think that is not problem. I think Vista is being annoying. Avrdude gives me also this error:
Help?
Choba
Re: Usbtiny version 2 on Vista not working
Postby sparr » Wed Oct 14, 2009 12:12 pm
To get the USBTinyISP to work in Vista 64 I had to reboot, press F8 for the boot menu (like for safe mode), and select the option to disable signed driver enforcement. There are apps that are supposed to duplicate that functionality without rebooting, but I couldn't get any of them to work.
sparr
Postby Choba » Wed Oct 14, 2009 1:00 pm
Thanks for the quick answer, that got rid of the error. :D Does this mean than whenever I want to use the USBtinyISP I have to select that option during booting?
I also got a new error. The one also mentioned on the documentation pages. The error is with rc=-1. I know this is with the connection/cables.
I tried to solve it, but don't know how. This might sound silly/stupid, but I don't get how the 6 pin header works.
I found this image (its from evilmadscientist):
But I don't get how that works for the 6 pin header. Is it from above? From bottom? ....
I made a new image, could you tell me what the 6 pins are?
Choba
Postby Choba » Wed Oct 14, 2009 1:54 pm
I figured it out.
1 +Vcc
2 MOSI
3 Ground
4 RESET
5 SCK
6 MISO
Now I get error it can't find the file. I did place it in C drive. Weird... :(
edit: I see it. I had to cd Desktop first.
HAHAHA! It works!!! :D
Choba
Postby SteveG » Wed Dec 16, 2009 3:40 am
sparr wrote:To get the USBTinyISP to work in Vista 64 I had to reboot, press F8 for the boot menu (like for safe mode), and select the option to disable signed driver enforcement. There are apps that are supposed to duplicate that functionality without rebooting, but I couldn't get any of them to work.
can we get this solution stickied? Had to wade through the threads and google before stumbling on this, vista 64 people need some lubbin too :wink:
SteveG
Postby adafruit » Wed Dec 16, 2009 10:41 am
sorry! we've been meaning to update the instruction for vista but Holidays Happened!
Postby mcsarge » Fri Dec 18, 2009 4:09 pm
adafruit wrote:sorry! we've been meaning to update the instruction for vista but Holidays Happened!
Can't we just get a signed driver instead? I think it is free.
<sig> Matt Sargent </sig>
mcsarge
Postby adafruit » Sat Dec 19, 2009 11:09 am
no idea how to do that :) usually you have to pay, no?
Postby mcsarge » Sat Dec 19, 2009 1:04 pm
adafruit wrote:no idea how to do that :) usually you have to pay, no?
Well, you can sign the driver yourself using this procedure:
http://www.minasi.com/newsletters/nws0903.htm
But you need Microsoft to cross sign it so others can used it (so it is trusted and that does cost money)...
You can still install it on other machines without the microsoft cross signature, but you have to put your computer in a test mode - it is described in the included link.
Matt
mcsarge
Postby adafruit » Sat Dec 19, 2009 1:11 pm
well if you have to put it in test mode -anyways- then whats the point?
Postby Choba » Sat Dec 19, 2009 1:19 pm
There was something with open source being free.
Here: http://www.certum.eu/certum/cert,offer_ ... ticode.xml
Choba
Postby mcsarge » Sat Dec 19, 2009 10:56 pm
adafruit wrote:well if you have to put it in test mode -anyways- then whats the point?
because you do not have to restart your computer _every_ time you want to use the programmer. We share our computer here at our house, so rebooting is a pain...
Matt
mcsarge
Postby adafruit » Sun Dec 20, 2009 1:26 am
ah! ok. we're going to try this out. not having used it on vista we dont know whats up :)
Postby rickrcomm » Thu Feb 04, 2010 1:08 pm
Was the Vista 64 signed driver issue with USBtiny ever stickied/solved?
thanks,
Rick
rickrcomm
Next
Return to USBtinyISP
Users browsing this forum: No registered users and 3 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
