Could not find USB device 0x1781/0xc9f
USB AVR Programmer and SPI interface. Adafruit's USBtinyISP.
Postby Archeious » Fri Dec 18, 2009 9:48 pm
I am using a kit I purchased a kit and assembled it. The green light is lit.
When I try to using the arduino software to burn a new bootload I get the error message "Could not find USB device 0x1781/0xc9f"
I am using Vista 32bit. I am also getting the same message with avrdude. I know not where to start troubleshooting.
It not recognizing it as a USB device on either of my PCs (Vista 32bit or Windows 7 x64)
Archeious
Re: Could not find USB device 0x1781/0xc9f
Postby Archeious » Sat Dec 19, 2009 3:34 pm
aye, I sure did. I turned off driver signing like it suggested and still no go.
Archeious
Postby adafruit » Sat Dec 19, 2009 3:59 pm
hmm. you have to restart perhaps?
Postby Archeious » Sat Dec 19, 2009 5:01 pm
On my Windows 7 x64 machine it is showing up as a malfunctioning device.
Archeious
Postby adafruit » Sat Dec 19, 2009 6:01 pm
check your soldering just in case. also, did you manage to install the driver?
Postby Archeious » Sun Dec 20, 2009 2:32 am
Good call. It looks like the solder join on D2 got too hot and pulled up the trace.on the side that hooks up to D1. I soldered a jumper wire between to teh two and now I get a
         this check.
I am trying to load in a new boot loader on a boardino (which I got from you guys a while back [and love it]). I will research the error but if it is something simple please let me know.
Archeious
Postby adafruit » Sun Dec 20, 2009 2:02 pm
check our FAQ/HEEEELP section. we provide a lot of hints but now your programmer works :)
Postby Archeious » Sun Dec 20, 2009 7:32 pm
adafruit wrote:check our FAQ/HEEEELP section. we provide a lot of hints but now your programmer works :)
I have read the FAQ and help sections. Unfortunately they did not help me. I also think I bricked ym boardino. The red light won't even flash now. I swapped out with a preprogrammed 328 and it won't flash either.
Archeious
Postby adafruit » Sun Dec 20, 2009 10:32 pm
well. ya something happened but if you didnt try to program the second chip its probably fixable. :)
Postby DaemonMaker » Thu Sep 16, 2010 8:47 pm
I'm experiencing this same error while trying to load a sketch via the Arduino IDE over USB. I'm using an Arduino Duemilanove. I am able to program the device via my USBtiny and avrdude without problems. The usbtiny is not connected to the Arduino or my Mac when I try to program via USB. Furthermore I know the USB port works as I can receive serial data in the Arduino environment.
I am running Arduino 0019 on OSX. I've made sure I have the latest FTDI drives. I've also verified that the appropriate Board and Serial Port are selected. Finally, though I'm sure the correct bootloader was already installed, I have reinstalled it. Has anyone else encountered this problem?
TIA,
Dustin
DaemonMaker
Postby adafruit » Thu Sep 16, 2010 10:50 pm
you're confusing FTDI and USBtinyISP
they are not the same things, and dont use the same drivers
you should use the USBtiny to upload a new bootloader to your adruino. they use the USB port on the arduino to upload new sketches
http://www.adafruit.com/blog/2010/09/15 ... l-special/
Postby DaemonMaker » Fri Sep 17, 2010 6:29 pm
I don't believe I am confusing FTDI and USBtinyISP. I understand they're different. I understand that I should not be seeing this error given the method of programming. None-the-less I am. When I try to program via the Arduino IDE (i.e. using USB) I see the error "Could not find USB device 0x1781/0xc9f" as though it's trying to use the ISP interface with the USBtinyISP. This is the source of my confusion and the impetus of my question.
Also, as I mentioned I did upload a new bootloader to my arduino but it did not correct the problem.
DaemonMaker
Postby adafruit » Fri Sep 17, 2010 6:55 pm
if you're saying "The usbtiny is not connected to the Arduino or my Mac when I try to program via USB. Furthermore I know the USB port works as I can receive serial data in the Arduino environment.
I am running Arduino 0019 on OSX. I've made sure I have the latest FTDI drives."
that sounds like you're confusing the two :)
if you can program an AVR with avrdude, the programmer is working fine...you've probably messed up something with the IDE while experimenting. posting -precisely- what you're trying to do will be helpful. dont say 'program via USB' because that can mean many different things
Postby DaemonMaker » Wed Sep 22, 2010 12:04 pm
I'm confused since the first thing I said stated precisely what I was trying to do... "load a sketch via the Arduino IDE over USB". I can only assume this is statement is unclear so I'll restate. I want to upload a sketch from the Arduino IDE to an Arduino Duemilanove. The error I receive while doing so is "Could not find USB device 0x1781/0xc9f". The aforementioned error implies that the Arduino IDE is trying to use a USBtinyISP to program the Arduino. However there is no USBtinyISP in play. The Arduino is connected to a MacBook Pro via USB and there are no other cables or devices in the mix. As far as the IDE goes, the only thing I did was install it, I've done no experimentation with it. This gives rise to two questions:
1) Can I program the device at all? Yes, if and only if I program it via ISP.
2) Is the USB connection working at some level? Yes, if I load a sketch that outputs serial data I can see that data in the Arduino IDE serial monitor.
So this leaves the question, why is the Arduino IDE trying to use a USBtinyISP when it should be using the USB connection?
My apologies for the confusion I hope that makes the issue more clear.
TIA,
Dustin
DaemonMaker
Next
Return to USBtinyISP
Users browsing this forum: No registered users and 4 guests
New Products [102]
LEDs[109]
Cables[60]
