Atmel Studio 6
Atmel Studio 6
Postby mymixed » Tue May 29, 2012 2:33 pm
I've been trying to set up Atmel Studio 6 w/ a USBtinyISP. I found this guide: http://webcache.googleusercontent.com/search?q=cache:http://grealish.co.uk/2011/avr-studio-5-and-usbtinyisp/, but its for studio 5. I tried it anyway, and it can successfully erase an ATtiny45. However, when it starts to program it, it gives me a couple errors. I'm using avrdude as an extension for Atmel Studio. Here's the avrdude output:
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude.exe: Device signature = 0x1e9206
avrdude.exe: NOTE: FLASH memory has been specified, an erase cycle will be performed
             To disable this feature, specify the -D option.
avrdude.exe: erasing chip
avrdude.exe: reading input file "3AC.cproj.hex"
avrdude.exe: error opening 3AC.cproj.hex: No such file or directory
avrdude.exe: input file 3AC.cproj.hex auto detected as invalid format
avrdude.exe: can't open input file 3AC.cproj.hex: No such file or directory
avrdude.exe: write to file '3AC.cproj.hex' failed
avrdude.exe: safemode: Fuses OK
avrdude.exe done.  Thank you.
Any help would be awesome. Thanks,
mymixed
mymixed
Re: Atmel Studio 6
Postby adafruit_support_rick » Wed May 30, 2012 10:10 am
It can't find the hex file to write to your chip. Check your directory settings.
Re: Atmel Studio 6
Postby mymixed » Wed May 30, 2012 1:41 pm
Where are the directory settings?
mymixed
Re: Atmel Studio 6
Postby adafruit_support_rick » Wed May 30, 2012 2:25 pm
I don't have Studio 6, so I can't answer that. But your link has the following picture:
My guess is that Studio 6 no longer defines the symbol $(BinDir). You'll need to figure out what symbol it uses instead, and then enter that symbol here. Find the makefile and see what's defined in there.
Or, maybe avrdude doesn't like filenames of the form nnnn.cproj.hex?
Re: Atmel Studio 6
Postby mymixed » Wed May 30, 2012 2:53 pm
Ok, now it's partially fixed. I'm still just sending it a while loop, but now it writes. It seems that avrdude was looking for the cproject, not the hex file. So I changed this:
-c usbtiny -p m328p -U flash:w:$(ProjectFileName).hex
to this:
and didn't modify anything else. However, now when it attempts to verify, I get a couple errors. Here is the entire avrdude output:
avrdude.exe: reading input file "3AC.cproj"
avrdude.exe: input file 3AC.cproj auto detected as raw binary
avrdude.exe: writing flash (4096 bytes):
Writing | ################################################## | 100% 2.76s
avrdude.exe: 4096 bytes of flash written
avrdude.exe: verifying flash memory against 3AC.cproj:
avrdude.exe: load data flash data from input file 3AC.cproj:
avrdude.exe: input file 3AC.cproj contains 4096 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 2.14s
avrdude.exe: verifying ...
avrdude.exe: verification error, first mismatch at byte 0x0000
             0xef != 0x00
avrdude.exe: verification error; content mismatch
avrdude.exe: safemode: lfuse changed! Was 62, and is now 0
Would you like this fuse to be changed back? [y/n]
Also, another problem is that I can't tell avrdude to change the fuse back or not since it's in the output window.
mymixed
Re: Atmel Studio 6
Postby luismasg » Sun Jun 10, 2012 3:59 am
hey, hi! i feel an absolute newbie and it gets frustrating not to have people close you can ask a question but i think i actually now what you can do. i havent finished reading the details of your screenshot but the point is : add a next level to the path argument. add a "/Debug/ whatever.hex:i " where your currently looking for there is no HEX file to write. you need to go to the compiler output folder.
get it? let me know.
*update* ok it works, no idea how to delete code but one click and it automatically uploads code into tiny 2313
this is what i wrote on argument line : -c usbtiny -p attiny2313 -U flash:w:debug/$(ItemFileName).hex:i
you just made my life a lot nicer , i really appreciated this one click programming from AVR S6 you have no idea.
cheers!!!
by the way, have you achieved hardware debugging ( DebugWire) with studio 6 and the usbtinyISP?
screen shot of avrdude succes and arguments
usbtiny- studio 6.jpg (172.42 KiB) Viewed 3387 times
luismasg
Return to USBtinyISP
Users browsing this forum: mibignistinly and 3 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
