USBTiny Issue AVRDUDE test - Initializaion Failed
by colinhart on Thu Dec 27, 2012 6:55 pm
Evening All
So I have started to look into the fun of electronics, and I embarked on my first soldering project over Christmas (A USBTiny),Yay. The guide on this site is awsome, I followed it step by step.
Now hoping (and hugging a tree) I think the soldering is good, however when I connect the USBTiny up to my Laptop (Linux Mint) and run
sudo avrdude -c usbtiny -p ATmega8 -F -vvvv
I get the following output.
avrdude: Version 5.11.1, compiled on Oct 30 2011 at 10:37:28
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/home/colin/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/parport0
         Using Programmer              : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 002:015
         AVR Part                      : ATMEGA8
         Chip Erase delay              : 10000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom         4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
           flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
CMD: [ac 53 00 00] [00 00 00 00]
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA8 is 1E 93 07
avrdude done.  Thank you.
Asking Dr Google as thrown up some possabilites but none that really fit my problem. The green light is on however when i execute the command the red light flashes once.
Any help solving this minor crises I have between any jobs you may have, drinking you may be doing would be greatly appreciated.
I am on a steep learning curve with electronics, so if you ask about components etc please throw me a bone? :oops:
colinhart
Re: USBTiny Issue AVRDUDE test - Initializaion Failed
by adafruit_support_rick on Fri Dec 28, 2012 9:08 pm
colinhart wrote:avrdude: initialization failed, rc=-1
This response from avrdude means that it can talk to the programmer but the programmer can't talk to the chip.
You'll find some suggestions for resolving this on our tutorial page
