- Code: Select all
~/robot/avrdude-5.3.1$ make
make all-recursive
make[1]: Entering directory `/home/stopgo/robot/avrdude-5.3.1'
make[2]: Entering directory `/home/stopgo/robot/avrdude-5.3.1'
yacc -d config_gram.y
config_gram.y:145.8-18: warning: symbol K_WRITEPAGE redeclared
if test -f y.tab.h; then \
to=`echo "config_gram_H" | sed \
-e 'y/abcdefghijklmnopqrstuvwxyz/ABCDEFGHIJKLMNOPQRSTUVWXYZ/' \
-e 's/[^ABCDEFGHIJKLMNOPQRSTUVWXYZ]/_/g'`; \
sed -e "/^#/!b" -e "s/Y_TAB_H/$to/g" -e "s|y\.tab\.h|config_gram.h|" \
y.tab.h >config_gram.ht; \
rm -f y.tab.h; \
if cmp -s config_gram.ht config_gram.h; then \
rm -f config_gram.ht ;\
else \
mv config_gram.ht config_gram.h; \
fi; \
fi
if test -f y.output; then \
mv y.output config_gram.output; \
fi
sed '/^#/ s|y\.tab\.c|config_gram.c|' y.tab.c >config_gram.ct && mv config_gram.ct config_gram.c
rm -f y.tab.c
if gcc -DHAVE_CONFIG_H -I. -I. -I. -DCONFIG_DIR=\"/usr/local/etc\" -Wall -g -O2 -MT avrdude-config_gram.o -MD -MP -MF ".deps/avrdude-config_gram.Tpo" -c -o avrdude-config_gram.o `test -f 'config_gram.c' || echo './'`config_gram.c; \
then mv -f ".deps/avrdude-config_gram.Tpo" ".deps/avrdude-config_gram.Po"; else rm -f ".deps/avrdude-config_gram.Tpo"; exit 1; fi
/bin/bash /home/stopgo/robot/avrdude-5.3.1/missing --run flex lexer.l
sed '/^#/ s|\.c|lexer.c|' .c >lexer.c
sed: can't read .c: No such file or directory
make[2]: *** [lexer.c] Error 2
make[2]: Leaving directory `/home/stopgo/robot/avrdude-5.3.1'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/stopgo/robot/avrdude-5.3.1'
make: *** [all] Error 2
I can get further in the compilation if I make again, but then I get a linker error. Any thoughts?
Also, you might want to include a check for flex and bison in your configure script, as the project seems to need it (or just mention the requirement when you mention that it needs libusb-dev).
