Sorry, this is probably a really stupid question, but I am an absolute beginner with this stuff. I just bought and assembled the USBtinyISP.
Using the test command
avrdude -c usbtiny -p m8
I get the response
avrdude: initialization failed, rc=-1
this check.
avrdude done. Thank you.
Which the tutorial indicates is good.
I have a spare ATMEGA328 chip, which has previously had the Arduino Uno boot loader uploaded to it. My question is, do I need to wire up any extra components to program the board, or is hooking it up to the 6 USBtinyISP pins sufficient? When I do this, and enter the command
avrdude -c usbtiny -p m328p
I get the same response as above, which I believe indicates that the programmer works, but cannot communicate with the chip. I have verified the connections several times.
Do I need to hook up crystals and such to the ATMEG328?
Anything else that I need to know?
Thanks for your help!
Programming an ATMEGA328
Re: Programming an ATMEGA328
Anybody?
I am very confused. I wired up a breadboard like it shows here
http://blog.thelifeofkenneth.com/2012/0 ... board.html
and still nothing.
When I put the chip on an Arduino Uno board, and connect the USBtinyISP to the ICSP headers, it works just fine. I get a device signature and everything. When connected to my breadboard, i get a device signature of 0x000000, by the way.
I checked continuity from the Arduino's ICSP pins to the Atmega328 Pins, to check that I have it connected right on the breadboard, and eveything on the Arduino is connected just as I have it on the breadboard, with the exception of the AREF pin, which I have tied to VCC.
Here is a picture of my breadboard. I have tried to chow the connections to the USBtinyISP, but its not that clear. it is color coded, though...
Can anyone offer any insight? I'm really stumped here.
and still nothing.
- adafruit_support_rick
Are you sure your clock is running? Hard to exactly see how you have everything wired, but it looks right.
You might want to refer to our ArduinoISP tutorial to double-check your wiring. For that, an arduino provides the SPI signals, instead of a USBTiny, but it's ultimately the same thing.
You might try different jumper wires and breadboard sockets. If you've got a multimeter, try to establish whyether on not you've got continuity between the target chip and the USBtiny pins. Also, make sure you've got the correct voltages, continuity with GND, etc.
