Power LED Turns off when Jumper
When I set the jumper to provide power to my chip using the jumper the green power led goes off on my tinyisp and arvdude says cannot be found. Any suggestions Thanks
Re: Power LED Turns off when Jumper
If you disconnect it from the chip, does the green light stay on? You may have a short in the circuit you are trying to power.
If you post photos of the front & back of the USBTinyISP board, we'll check the assembly.
No I had it unplugged when i changed the jumper. Disconnected from the chip the led will turn off the second I connect the jumper
- P1080231 (Large).JPG (287.52 KiB) Viewed 740 times
- P1080230 (Large).JPG (297.8 KiB) Viewed 740 times
- P1080228 (Large).JPG (337.58 KiB) Viewed 740 times
Post photos then. We'll check out your assembly.
yeah forgot them
- P1080232 (Large).JPG (265.25 KiB) Viewed 740 times
IC2 is installed backwards. Make sure that the notch on the chip lines up with the notch on the silkscreen.
well that probably explains it. I've had this thing sitting around for five years and this is first time to use it. Thanks for the help!
