Trinket HELP
technobly
Re: Trinket HELP
Post by technobly »
@johnweythek can you explain exactly what you are doing with the updated .exe? It sounds like you are just unzipping it and running it. You need to backup your old one, and drop the updated one in the C:\arduino-1.0.5\hardware\tools\avr\bin\ directory. Like so:
Then run the commands to program the trinketblink.hex from the command line.
If you are getting this error you have to modify your avrdude.conf file by removing lines 1516 through 1632. I've attached mine if you don't want to do that. It's in a zip file because the forum wouldn't let me upload a .conf file directly...
You'll want to backup your old avrdude.conf like your .exe and copy the .conf file to both of these directories:
C:\arduino-1.0.5\hardware\tools\avr\etc\
This part of the location may be different on your computer:
C:\arduino-1.0.5\
avrdude.zip
avrdude.conf zipped up
(24.74 KiB) Downloaded 186 times
johnweythek
Re: Trinket HELP
Post by johnweythek »
Thank you for the hand-holding super noob instructions. Seriously, i see and exe, i execute it, other files were replaced and changed though. Seriously thanks, i am dumb at this trinket for some reason.
No more constant bootloader. Tried Uploading blink and got an oarnge message that said
"avrdude: Trinket Bootloader selected"
but no blinking light and no other errors. I can feel it getting closer. Is it working? just not with blink? or is there something else i missed. It's a weird error to tell me it's basically working.
Is the 'trinket friendly' IDE supposed to just work after install? I'm about to fire up an old rig just to see if that'll work instead. Well, old still has windows 7 and i know there were usbtiny problems with that from the start so my hopes aren't exactly up.
Thanks again for the help. You spent a lot of time on that response i can tell. I'm glad there's you and bill and the rest of the supportive community on the forums.
technobly
Re: Trinket HELP
Post by technobly »
@johnweythek as long as you still have patience to keep working on solving the problem, I'm determined to help you :)
Sounds like you are not using the avrdude.exe from the command line, but rather the ArduinoIDE. You can download the pre-modified ArduinoIDE and it will work for the Trinket (at least it did for me). THE FAST WAY here is what you want: http://learn.adafruit.com/introducing-t ... rduino-ide
I preferred to modify my current IDE because I have other modifications done to it that change the theme and different libraries already installed.
One thing to note is that when you press the reset button on the Trinket, it puts it into bootloader mode for at least 10 seconds. During that time the RED LED will pulse with a fade in/out pattern. The default trinketblink sketch blinks the RED LED on and off at a similar rate, without the fade in/out. I like to modify the delay times to see if it in fact is programming each time.
Here's an obvious change to the default sketch that makes the LED blink on and off faster:
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
  To upload to your Gemma or Trinket:
  1) Select the proper board from the Tools->Board Menu
  2) Select USBtinyISP from the Tools->Programmer
  3) Plug in the Gemma/Trinket, make sure you see the green LED lit
  4) For windows, install the USBtiny drivers
  5) Press the button on the Gemma/Trinket - verify you see
     the red LED pulse. This means it is ready to receive data
  6) Click the upload button above within 10 seconds
int led = 1; // blink 'digital' pin 1 - AKA the built in red LED
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
    digitalWrite(led, HIGH);
    delay(300);
    digitalWrite(led, LOW);
    delay(300);
And one that blinks really slow:
  Blink
    delay(2000);
    delay(2000);
If you kind of alternate between these, you should see it program each time. Don't forget to press the reset button before you hit the upload button.
BTW the "avrdude: TRINKET BOOTLOADER SELECTED" message is not actually an error, and you should see it twice each time you upload a sketch.
Your IDE status bar should say Compiling Sketch, and then Uploading Sketch and then Upload Complete.
adafruit_support_rick
Re: Trinket HELP
Let's try replacing your Trinket. Please email [email protected] with a link to this thread for a replacement
johnweythek
Re: Trinket HELP
Thanks, i have several trinkets to test so it's not a faulty unit as the same happens on my other 3V one, thanks for the offer though. Good that my error wasn't an error.
I am gonna mess with those timing numbers because my blink code wasnt nearly that short (300) more like 1000.
ITS BLINKING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :shock: :shock: :shock: WOWOWOWOWOWOW! Thank you all so very much. I hope i can do this for someone else on the forum one day. Oh boy, changed blink timings and they changed on the trinket, FINALLY time to put my projects together. This has been a great learning experience for me and hope to do it all right any time i have to in the future. I'll prob be back with more questions but this is a huge step. Thanks again to everyone who chipped in, you have made a tinkerer very, very happy indeed. :D :D :D :D :D :D
johnweythek
Re: Trinket HELP
AWE YEAH!!!!! It's handling everything from the neopixel library! Decided to use the gemma for the goggles since it has the JST connector and i wanted to wear some gear on the outside for nerd pride and all. Trinket's powering my xmas ornament, though, i have to use the USB shielding for ground because the ground pin resets it, i'm guessing that's a 'plugged in' problem and will go away with a battery on it. Thanks again, i'm still riding high on the excitement of new projects!
technobly
Re: Trinket HELP
Post by technobly »
@johnweythek Awexome! Can't wait to see what you come up with ;-)
BTW, here's my first project with the Trinket: http://www.youtube.com/watch?v=O3Cr7Nu0i1Y
technobly
Re: Trinket HELP
Post by technobly »
johnweythek wrote:though, i have to use the USB shielding for ground because the ground pin resets it, i'm guessing that's a 'plugged in' problem and will go away with a battery on it.
If you have a sketch programmed already, and plug in power... the Trinket will power up in bootloader mode for 10 seconds and then it will run your code. Maybe this is what you are seeing? You should be able to hook up standard mini USB wall adapter, and connect your neopixel's VCC to the USB pin of the Trinket. If you are going to add a battery then you probably want to follow the adafruit guide here that shows adding a 3.7V Lipo to the BATT pin of the trinket along with your neopixel VCC http://learn.adafruit.com/larson-scanne ... -soldering
johnweythek
Re: Trinket HELP
Nice job there. rings and shields will make for great illumination in translucent objects like that. I'm sticking (mostly) to the adafruit tutorials until i run out of cool stuff. I think i am already tasked with making a light up tacky xmas sweater for my father-in-law. Got a sheet of wearable friendly pixels and some conductive thread on the way, now for the tacky sweater...
The Goggles are def my 1st project though i went for red rather than the provided green for a scarier look (because i started this before halloween, ha) but rainbow swirls are awesome too and The big lipo battery has been going all night and day. I also have a 'nightvision' program which is simply all set to hi white, which honestly gives you vision in the dark, so, the name works. Almost no light bounce back with no lenses or the right placement of black sugru. After i get some strands of neopixels my desk is gonna have some crazy ambient light effects as well (to add to my adalight monitor kit). Even with all that there's no end in sight for my adventures in gadgetry.
I can't thank you guys enough times for all the help so i'll do it again, THANKS!!!
technobly
Re: Trinket HELP
Post by technobly »
Sounds like you have NeoPixel Fever ;-) Nothing wrong with that... only way to keep it in check is to build lots and lots of NeoPixel projects! Happy Making!!
Mischa77
Re: Trinket HELP
Post by Mischa77 »
Thank you very very much for your first post.
There were no solutions to find, but I had the same problem of not being able to connect.
Pressing the reset button while compiling works for me.
Thanks again
Mischa77
Re: Trinket HELP
Post by Mischa77 »
Sorry, my last post was about this site:
http://codergirljp.blogspot.nl/2014/01/ ... de-in.html
worked very well for my problem. Sorry, if it's a different subject
makerspace_aurich
Re: Trinket HELP
Post by makerspace_aurich »
In our makerspace we build 6 POI-Genesis with trinket 5V.
Under XP everything works correct. Under Windows 7 (64bit) we get no error while compiling. But when we tried to load the program into the trinket (the LED fades correct on an off) we get always the error message "avrdude: error: usbtiny_receive: (expected 4, got -5)". We tried to deinstall of the trinket driver and install it again. We tried to install the driver without license. Always It comes the same error. Now we´ve no more idea. It´s always (expected 4, got -5) and not (expected 4, got -71) or samething similair.
Mischa77
Re: Trinket HELP
Post by Mischa77 »
Have you tried resetting it just before the upload ends? Or disconnect every I/O pin while uploading? Not a desired work flow but it worked for me.
nekollx
Re: Trinket HELP
Post by nekollx »
I installed the arduino IDE, i can verrify my files but when i go to upload it gives a ton of errors seemingly timout based and yet i installed the conf file from the adafruit build
Arduino: 1.6.4 (Windows 7), Board: "Pro Trinket 5V/16MHz (USB)"
Sketch uses 2,836 bytes (9%) of program storage space. Maximum is 28,672 bytes.
Global variables use 42 bytes of dynamic memory.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
Return to “USBtinyISP”
