attiny2313 in usbtinyisp corrupted
The Hall effect comes about due to the nature of the current flow in a conductor. Current consists of the movement of many small charge-carrying "particles" (typically, but not always, electrons). These charges experience a force, called the Lorentz Force, when a magnetic field is present that is not parallel to their motion. When such a magnetic field is absent, the charges follow an approximately straight, 'line of sight' path. However, when a perpendicular magnetic field is applied, their path is curved so that moving charges accumulate on one face of the material. This leaves equal and opposite charges exposed on the other face, where there is a dearth of mobile charges. The result is an asymmetric distribution of charge density across the hall element that is perpendicular to both the 'line of sight' path and the applied magnetic field. The separation of charge establishes an electric field that opposes the migration of further charge, so a steady electrical potential builds up for as long as the current is flowing.
in a perfect world, the girls would be all over guys like youwtfwtfdef wrote:The Hall effect comes about due to the nature of the current flow in a conductor. Current consists of the movement of many small charge-carrying "particles" (typically, but not always, electrons). These charges experience a force, called the Lorentz Force, when a magnetic field is present that is not parallel to their motion. When such a magnetic field is absent, the charges follow an approximately straight, 'line of sight' path. However, when a perpendicular magnetic field is applied, their path is curved so that moving charges accumulate on one face of the material. This leaves equal and opposite charges exposed on the other face, where there is a dearth of mobile charges. The result is an asymmetric distribution of charge density across the hall element that is perpendicular to both the 'line of sight' path and the applied magnetic field. The separation of charge establishes an electric field that opposes the migration of further charge, so a steady electrical potential builds up for as long as the current is flowing.
but, seriously, even if he was dropping neodimium iron boron, with no return path the flux wont be nothing, certainly not enough to program an atmel due to current induced on leads .1 long. i mean, guy, look at the spec - you have to send a sequence of bytes.
