I've been looking over the pinouts for the Trinket: http://learn.adafruit.com/introducing-trinket/pinouts ,but I'm not sure I understand it well enough. Are there any external interrupts on the Trinket microcontroller?
External Interrupts on Trinket?
Re: External Interrupts on Trinket?
PB2 on the chip is INT0 (among other things) the sole external interrupt on the ATTiny85. This is brought out as GPIO#2 on the Trinket.
- docwisdom
Sorry to dig up an old thread, but can you do external interrupt and I2C on the Trinket at the same time?
- adafruit_support_rick
Sure! Just don't use the interrupt pin for I2C.docwisdom wrote:can you do external interrupt and I2C on the Trinket at the same time?
- lukebo
Hi everyone,
sorry to dig out that old thread again!
I did not really understand your answer, Rick. My problem is as follows. I want to use the trinket to grab the signal of an anemometer (10101010101 with a certain frequency) and measure that frequency. The result must be sent over I2C to a master for further processing. If i use GPIO2 to measure the frequency using the (only) interrupt, how can i use it as I2C clock line at the same time!?!? Can the clock line be changed? I always thought that it is fixed?
Thanks for the help,
Luke
Luke
The external interrupt would interfere with i2c. But you can use pin-change interrupts. Pin change interrupts (PCINTx) are supported on all of the GPIO pins.
- lukebo
Thanks a lot for the keywords, Bill!
