I'm experiencing a weird issue when using avrdude + usbtinyisp on an attiny84 chip.
Here is the error:
avrdude -c usbtiny -p attiny84 -U lfuse:w:0xe2:m -U hfuse:w:0xd7:m -U efuse:w:0xff:m -U eeprom:w:.eeprom.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e930c
avrdude: reading input file "0xe2"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xe2:
avrdude: load data lfuse data from input file 0xe2:
avrdude: input file 0xe2 contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xd7"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd7:
avrdude: load data hfuse data from input file 0xd7:
avrdude: input file 0xd7 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xff"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xff:
avrdude: load data efuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file ".eeprom.hex"
avrdude: input file .eeprom.hex auto detected as Intel Hex
avrdude: writing eeprom (16 bytes):
Writing | ######################### | 50% 4.05s
avrdude: error: usbtiny_send: usb_control_msg(DeviceRequestTO): transaction timed out (expected 128, got -60)
Writing | ################################################## | 100% 7.02s
avrdude: 16 bytes of eeprom written
avrdude: verifying eeprom memory against .eeprom.hex:
avrdude: load data eeprom data from input file .eeprom.hex:
avrdude: input file .eeprom.hex contains 16 bytes
avrdude: reading on-chip eeprom data:
Reading | ################################################## | 100% 0.70s
avrdude: 16 bytes of eeprom verified
avrdude: safemode: Fuses OK (H:FF, E:D7, L:E2)
avrdude done. Thank you.
prepare-chip:
@# Generate a random serial number using uuidgen.
$(ECHO_NOTHING)uuidgen | tr -d '-' | head -c 16 > .tmp.txt$(ECHO_END)
@# Create an eeprom file (Intel Hex) using avr-objcopy.
$(ECHO_NOTHING)avr-objcopy -I binary -O ihex .tmp.txt .eeprom.hex$(ECHO_END)
@# Upload the eeprom file & set the correct fuses.
@echo "Setting fuses and writing eeprom..."
$(ECHO_NOTHING)rm -rf .tmp.txt .eeprom.hex$(ECHO_END)
