problems with usbtiny 2.0 from a kit.
USB AVR Programmer and SPI interface. Adafruit's USBtinyISP.
batmatt08
Re: problems with usbtiny 2.0 from a kit.
Post by batmatt08 »
Hi rick I did re-soldered the board. 're checked for cross soldering or bridges nothing . Still have 5.0 vts without the jumper. Any more thoughts ??
batmatt08
Post by batmatt08 »
Hi rick I did re-soldered the board. 're checked for cross soldering or bridges nothing . Still have 5.0 vts without the jumper. Any more thoughts ?? Thx.
adafruit_support_rick
Post by adafruit_support_rick »
Are you sure you're testing the right pin?
batmatt08
Post by batmatt08 »
Yes. Positive 100% . I checked the pins before plug anything on it. 3 times also the isp plug has a little arrow for pin 1 . Cant miss that . Pin 2 is vc 5.0vts PIN 6 is ground . After remove the jumper I still have 5.0vts . Thx
Well, if you look at the schematic, you'll see that there's absolutely no place for that to come from, unless your buffer chip is slagged. You are checking this with the target disconnected, right?
http://learn.adafruit.com/system/assets ... sp2sch.png
batmatt08
Post by batmatt08 »
Yes. I disconnected the target and placed a led on it when I disconnect the jumper the led stays on.I placed the led on pin 2 and 6 of the 6 pin isp cable.
Well, I guess your buffer chip must be shorted out somehow. Please email [email protected] with a link to this thread for a replacement USBtinyISP kit.
batmatt08
Post by batmatt08 »
HI RICK i just did . thanks for your help . you were very helpful.
gpoteau
Post by gpoteau »
Hello, I have the same situation here, but if i remove the buffer chip I do not get the 5 volt with the jumper off, I will check with a new 74HAC125N chip, as you suggest that it may be in fault.
batmatt08
Post by batmatt08 »
Hi . Yes you might have a faulty buffer chip. Let me ask you did you recently purchased this unit?
gpoteau
Post by gpoteau »
I have it since nearly a year, but the fact is the programmer is still working.
batmatt08
Post by batmatt08 »
I'm just wondering if could be a bad batch of those ic.s.
gpoteau
Post by gpoteau »
I replaced the buffer chip per a MC74F125N, everything it's ok now.
As soon as I get a 74AHC125N I will use it instead of the MC74F125N. The MC74F125N operate only at 5v, the 74AHC125N allow lower voltage, and so can be use as level shifter.
batmatt08
Post by batmatt08 »
Ok. Cool. My situation is I just got this device and it came like that I just want it a factory working product if I had it for a long time it will be ok. Best luck . And thx.
Return to “USBtinyISP”
