I have a problem with the upper command. When I type it in (while I'm in SPI directory) the process stops like this:
(Fuse-programming ok...)
avr-gcc (...) crc.S
avr-gcc (...) int.S
avr-gcc (...) main.o main.c
avr-gcc -g -mmcu=attiny2313 -o main.elf crc.o int.o usb.o main.o
process_begin: CreateProcess((null), python ../usbtiny/../util/check.py main.elf 32 2048 128, ...) failed.
make (e=2): Das System kann die angegebene Datei nicht finden.
make: *** (main.hex) Error 2
I installed WinAVR2007 and, as it didn't work, WinAVR2005 - same problem with both versions...
Do you know how to handle this problem?
Best regards,
Andi
