SOLVED: Need Help Programming Adafruit USB Power Gauge
Camjuar
Post by Camjuar »
Can anyone explain how to use USBTinyISP and avrdude to load the files in https://github.com/adafruit/USB-Power-Gauge onto the power gauge?
The command
avrdude -c usbtiny -p t85
is giving me
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e930b
avrdude: safemode: Fuses OK (H:FE, E:D5, L:F1)
avrdude done.  Thank you.
Update(5/7/2014): I solved this using the instructions for setting up Arduino IDE for Trinket located at https://learn.adafruit.com/introducing- ... rduino-ide and setting my Board in the IDE to Trinket 16MHz.
Afterwards I was able to upload code to the power gauge using the IDE.
adafruit_support_rick
Re: Need Help Programming Adafruit USB Power Gauge
Go into the Preferences panel of the Arduino IDE, and check verbose output on compile. Close the panel and restart the IDE. When you compile the firmware, you will see the path and name of the hex file in the output window, just before the line telling you how many bytes were used. It will look something like this:
/var/folders/rm/42sbjlxr8xj2q60059_spx7r0000gn/T/build5835127476841864561.tmp/sketch_apr30a.cpp.hex
Camjuar
Post by Camjuar »
I see, thanks! I'm trying to compile the source from the repo (unaltered) and receiving a number of errors. I'm using Arduino IDE and have the board set to ATtiny85 (internal 8 Mhz clock) and the Programmer set to USBTinyISP.
Here is what I'm seeing
In file included from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Stream.h:26,
from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/libraries/SoftwareSerial/SoftwareSerial.h:36,
from adafruit_usbpowergauge.ino:18:
/Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:32:1: warning: "BIN" redefined
In file included from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/avr/iotn85.h:38,
from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/avr/io.h:284,
from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/avr/pgmspace.h:82,
from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:29,
from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:26,
/Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/avr/iotnx5.h:55:1: warning: this is the location of the previous definition
adafruit_usbpowergauge.ino: In function 'void setup()':
adafruit_usbpowergauge.ino:87: warning: only initialized variables can be placed into program memory area
adafruit_usbpowergauge.ino:96: warning: only initialized variables can be placed into program memory area
adafruit_usbpowergauge.ino:98: warning: only initialized variables can be placed into program memory area
adafruit_usbpowergauge.ino: In function 'void loop()':
adafruit_usbpowergauge.ino:139: warning: deprecated conversion from string constant to 'char*'
adafruit_usbpowergauge.ino:144: warning: deprecated conversion from string constant to 'char*'
adafruit_usbpowergauge.ino:148: warning: deprecated conversion from string constant to 'char*'
adafruit_usbpowergauge.ino:150: warning: deprecated conversion from string constant to 'char*’
from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/HardwareSerial.h:28,
from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:193,
from analog.cpp:15:
from /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:8,
from analog.cpp:15:
from charlie.cpp:16:
/Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25/crttn85.o:(.init9+0x2): relocation truncated to fit: R_AVR_13_PCREL against symbol `exit' defined in .fini9 section in /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25/libgcc.a(_exit.o)
adafruit_usbpowergauge.cpp.o: In function `printDotDecimal(unsigned int, unsigned char)':
/Users/cam/Applications/adafruit_usbpowergauge.ino:117: relocation truncated to fit: R_AVR_13_PCREL against symbol `__udivmodhi4' defined in .text.libgcc section in /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25/libgcc.a(_udivmodhi4.o)
/Users/cam/Applications/adafruit_usbpowergauge.ino:117: relocation truncated to fit: R_AVR_13_PCREL against symbol `Print::print(unsigned int, int)' defined in .text._ZN5Print5printEji section in core.a(Print.cpp.o)
/Users/cam/Applications/adafruit_usbpowergauge.ino:120: relocation truncated to fit: R_AVR_13_PCREL against symbol `__udivmodhi4' defined in .text.libgcc section in /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25/libgcc.a(_udivmodhi4.o)
/Users/cam/Applications/adafruit_usbpowergauge.ino:121: relocation truncated to fit: R_AVR_13_PCREL against symbol `__udivmodhi4' defined in .text.libgcc section in /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25/libgcc.a(_udivmodhi4.o)
/Users/cam/Applications/adafruit_usbpowergauge.ino:121: relocation truncated to fit: R_AVR_13_PCREL against symbol `Print::print(unsigned int, int)' defined in .text._ZN5Print5printEji section in core.a(Print.cpp.o)
/Users/cam/Applications/adafruit_usbpowergauge.ino:125: relocation truncated to fit: R_AVR_13_PCREL against symbol `__udivmodhi4' defined in .text.libgcc section in /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25/libgcc.a(_udivmodhi4.o)
/Users/cam/Applications/adafruit_usbpowergauge.ino:125: relocation truncated to fit: R_AVR_13_PCREL against symbol `Print::print(unsigned int, int)' defined in .text._ZN5Print5printEji section in core.a(Print.cpp.o)
adafruit_usbpowergauge.cpp.o: In function `loop':
/Users/cam/Applications/adafruit_usbpowergauge.ino:134: relocation truncated to fit: R_AVR_13_PCREL against symbol `__mulsi3' defined in .text.libgcc section in /Users/cam/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25/libgcc.a(_mulsi3.o)
/Users/cam/Applications/adafruit_usbpowergauge.ino:134: additional relocation overflows omitted from the output
Any ideas?
Return to “USBtinyISP”
