I just built the USBtinyISP v2.0 programmer. But It keeps giving me the following:
C:\avr>avrdude -c usbtiny -p attiny2313 -U flash:w:default.hex
this check.
avrdude done. Thank you.
1. downloaded/installed the WinAVR as per the manual.
2. installed the ISP with the USB driver 1.12 (driver manager on windows says it is 1.12.1)
3. replaced the avrdude (3 files) from WinAVR with the avrdude 5.3.1 files.
4. rebooted a couple times (yes I'm used to windows...)
I'm pretty sure I built the kit correctly. I have a fair amount of electronics experience. I'm using a target OLIMEX board for the attiny2312. It has +5v on it which is coming from the USB programmer (JP3 is connected), so I think the cables are correct.
I have spent a couple hours poking around the forum and nothing I see seems to help me get beyond this.
Your help is greatly appreciated?
C.
