The green LED is not lighting up when plugged in, but it appears my computer can communicate with the USBTiny because sending avrdude -c usbtiny -p m8 causes the red LED to light up once and the expected result is printed on the command line: initialization failed rc=-1.
I have also tried programming a 168PA-PU, but got an initialization failed rc=-1 error, but I am unsure if the lack of a green light is the cause.
Images of the USBTiny attached.
EDIT: I should add that I have tested the green LED and it works.
Green LED not lit, but can still talk
- Front 1
- IMAG0512.jpg (762.91 KiB) Viewed 934 times
- Front 2
- IMAG0511.jpg (781.1 KiB) Viewed 934 times
- Back
- IMAG0510.jpg (658.07 KiB) Viewed 934 times
- adafruit_support_rick
Re: Green LED not lit, but can still talk
Looks like you forgot to install R4.
Update: Was checking the path that lights the LED and Pin 9 on the ATTiny is only outputting 1 V--is that right?
Thanks for the response. I added R4, but still no light.
Images attached.
Images attached.
- Back
- IMAG0514.jpg (512.02 KiB) Viewed 916 times
- Front
- IMAG0513.jpg (766.1 KiB) Viewed 916 times
The red LED will only light while programming is happening. What's going on with avrdude now that you have R4 installed?
Same behavior as before:
OK. In that case, there's something wrong with your target. Make sure you have the right orientation on the cable to the target. Make sure the target has power, and make sure the target has a clock source - either it has an external crystal or it's configured o use an internal clock
Thanks for your reply.
I don't see how the target would effect my green LED not lighting up though. My two current problems:
1. Power-on green LED not working.
2. avrdude is returning an rc=-1 error with a 168PA-PU as my target.
Regarding (1) I have found:
* The path from Pin 9 to LED2 is OK, tested with my multimeter.
Regarding (2) I have found:
* I am measuring very little voltage on VCC on my ten-pin connector
What voltage are you seeing at Pin 9?cacciatc wrote:Regarding (1) I have found:
Are you sure you have LED2 installed the right way around?
What voltage are you seeing at LED2?
You're looking at Pin 2 of the connector?cacciatc wrote:Regarding (2) I have found:
You have the USB PWR jumper installed?
What voltage do you see at the USB PWR jumper?
Do you have a different USB cable you can try? Also a different USB port on your computer?
(1)
5V
Yes, I can light the LED by applying current and the leads are in correctly.
0v
(2) You have the USB PWR jumper installed?
Nope, you called it! I am now getting the expected response from avrdude:
5V
0v
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude.exe: Device signature = 0x1e940b
avrdude.exe: Expected signature for ATMEGA168 is 1E 94 06
Double check chip, or use -F to override this check.
avrdude.exe done. Thank you.
Cool! Let us know if you have any more trouble!cacciatc wrote:I am now getting the expected response from avrdude:
