Red LED doesn't blink, bootloader doesn't run
I plugged in my Gemma for the first time and sat down with the Adafruit Arduino IDE. The red led dimly blinks once and stops, both when the Gemma is first plugged in and when I press the reset button. Trying to upload the blink sketch gives me the error that happens when the bootloader isn't running.
- adafruit_support_rick
Re: Red LED doesn't blink, bootloader doesn't run
You can repair the bootloader by following these instructions:
https://learn.adafruit.com/introducing- ... bootloader
Ok, so, it wasn't the gemma, it's something about my computer, it worked as soon as I tried it on a friend's. Could it be that I have USB 3.0?
Try a different USB port. Also, try connecting through a self-powered USB hub. Trying a different cable is also a good idea.
- enurbs2015
Does this happen on Macs?
- Franklin97355
The USB 3 problem does.
