I just recieved my USBTINY kit rev 2.0 from adafruit. Assambled it together. Also recieved a BAREBONES AVR DEV. BOARD kit. Soldered that also!
With the Dev board there was a Atmega328-PU chip coming. I also ordened an 16MHZ crystal from adafruit site. Now when i try to use the chip i get the following error:
C:\Users\BANNED>avrdude -c usbtiny -p m328p
this check.
avrdude done. Thank you.
What am i doing wrong, Photo's Attached from the soldering and the chips:
Much thanx!!
Greets Willem
USBTINYISP programmer with ATMEGA328-PU
- adafruit_support_rick
Re: USBTINYISP programmer with ATMEGA328-PU
That ATmega328 is preprogrammed with the Arduino bootloader. It has also been programmed to expect an external crystal. You will need to add a crystal to your barebones dev board.
- wtrader1
I had a 16MHZ crystal!
i was forgotton to do the 2 resistors with a piece of wire!
