Is it possible to use the USBtinyISP as a clock source?
dawtty
Post by dawtty »
So I goofed up and set the lfuse bit of an Attiny84 to 0xC0 which apparently means that I set "the fuses for an external clock with no divider". I read that somehow I might be able to use the programmer as the external clock source? If that's not the case, what are my other options to restore functionality to my chip? Thanks
adafruit_support_rick
Re: Is it possible to use the USBtinyISP as a clock source?
Hmmm. Don't know where you read that. I don't know of a way to use the programmer as a clock source.
We stock resonators that you can use as a clock:
https://www.adafruit.com/products/1872
nsayer
Post by nsayer »
With the fuses set that way, a resonator or crystal will not work. It's configured for a direct square wave on CLKI.
You can't use a USBTiny as a clock source, but if you happen to have an Arduino UNO handy, it's pretty easy to configure it as a square wave source to recover from bad fusing. Just write a sketch like this:
setup() { pinMode(3, OUTPUT); }
loop() {
while(1) {
digitalWrite(3, HIGH);
digitalWrite(3, LOW);
That's not going to be perfectly square, but it will be good enough. With a 16 MHz Arduino, you'll probably wind up with a clock around 1 MHz or so.
And then connect D3 to CLKI (pin 2) on your Tiny84 and attempt to re-fuse the chip. If it doesn't work immediately, try using a -B argument to avrdude to slow down the SPI clock.
nsayer
Post by nsayer »
So, since I posted that, I actually *have* figured out a way to make a USBTiny (or a clone) generate a "recovery clock" - a 500 kHz square wave that you can inject onto one or the other XTAL pin on a controller that you've accidentally fused for an external crystal.
To make it work, you have to upload new firmware. The new firmware sets up OC0A (PB2) as an output from one of the timers.
Here's the patch against the v1.7 source code:
--- main.c.orig	2015-02-18 00:09:51.871774909 -0800
+++ main.c	2015-02-24 22:55:16.889267234 -0800
@@ -44,12 +44,14 @@
 #define	PIN		PINB
 #define	LED		PB0		// output
+#define	RCLK		PB2		// output
 #define	RESET		PB4		// output
 #define	MOSI		PB5		// output
 #define	MISO		PB6		// input
 #define	SCK		PB7		// output
 #define	LED_MASK	_BV(LED)
+#define	RCLK_MASK	_BV(RCLK)
 #define	RESET_MASK	_BV(RESET)
 #define	MOSI_MASK	_BV(MOSI)
 #define	MISO_MASK	_BV(MISO)
@@ -193,7 +195,7 @@
 			mask |= RESET_MASK;
 		CLR(BUFFEN);
-		DDR  = LED_MASK | RESET_MASK | SCK_MASK | MOSI_MASK;
+		DDR  = LED_MASK | RESET_MASK | SCK_MASK | MOSI_MASK | RCLK_MASK;
 		PORT = mask;
 		return 0;
@@ -295,6 +297,11 @@
 extern	int	main ( void )
+	// Initialize timer 0 for 500 kHz clock on PB2 (OC0A)
+	TCCR0A = _BV(COM0A0) | _BV(WGM01); // CTC mode, toggle OC0A on match
+	TCCR0B = _BV(CS00); // No prescaling
+	OCR0A = 11; // divide system clock by 24 -> 500 kHz
 	SET(BUFFEN);
 	OUTPUT(BUFFEN);
 	usb_init();
Having done this, PB2 will have a 500 kHz square wave on it whenever programming is in progress. You need to use -B 250 with avrdude to give the target enough time to stabilize after the clock appears (when RESET is brought low), but I've used this as a test to recover an intentionally pooched ATTiny85.
Interesting. Thanks for posting!
Return to “USBtinyISP”
