ADAFruit folks,
I'm in a spot here were I need to update the firmware (Mac Yosemite with Linux Dev platform via virtualbox). I've used the arduino megaISP code to burn non-boot loader code 328p (before I got the USBTinyISP). I find myself hesitant to just "wire it up" with the USBtimyISP uC.
Any cautions/suggestions on using the arduino megaISP code to re-flash the USBtinyISP uC?
Thanks.
firmware update via arduino MegaISP
Re: firmware update via arduino MegaISP
For those with the virtualbox USB problem on the USBtinyISP v2, here's how I fixed it.
Premise: need to reflash the firmware with usbtiny v1.05+. on site HW limited to Arduino Uno, bread board, jumper wires (seriously, that's all I had available).
follow directions to load ArduinoISP via normal processes.
pull 2313 out of usbtinyisp and put in BB.
connect Arduino10:Tiny1, A11:T17, A12:T18, A13:T19.
Connect T20 vcc, T10 gnd.
You need the oscillator from the USBtinyISP. Connect T4 to Socket4, T5:S5.
You need to connect S10:gnd and S20:vcc
When you run avrdude use the following (correct location for relative path and devices)
Put USBtinyISP back together. DO NOT PLUG IN YET.
After that, create a rule in virtualbox VM USB section. USBtinyISP will show up as 107.
Now plug in USBtinyISP. You should see the following output from lsusb
jaysen@avr-dev:~/usbtiny-1.7/usbtinyisp$ avrdude -cavrisp -pt2313 -P /dev/ttyACM0 -b19200 -U flash:w:main.hex
jaysen@avr-dev:~/usbtiny-1.7/usbtinyisp$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 002 Device 005: ID 1781:0c9f Multiple Vendors USBtiny
