i try to update this "empty" code to Gemma2
// put your setup code here, to run once:
// put your main code here, to run repeatedly:
avrdude: error: usbtiny_transmit:
this check.
in cmd with
avrdude -c usbtiny -p attiny85 -F
i get this information:
avrdude: error: usbtiny_transmit: usb_control_msg: sending control message faile
d, win error: Ein an das System angeschlossenes Gerõt funktioniert nicht.
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATtiny85 is 1E 93 0B
avrdude done. Thank you.
btw:
window 7
Arduino 1.6.5
avrdude is 5.11
