Hi All
i need to create a 2000Hz square wave on a tiny. i do most on the UNO and get close with the blink default and
do the following:
int val = 244; //=1993/ 244= 2006
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delayMicroseconds(val); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
changing pin 13 to o for the tiny using same code the first tiny is 241hz the second is at 239hz and so on
I have to have a better control over the accuracy as the tolerance needed is about 1 hz
the tiny45 is at 1MHz and are all different.
What am i doing different / wrong?
any help would be great
bgs
uno 2000hz to tiny 45 not the same
