I am having trouble getting code to compile without getting errors.
I have copied and pasted several sample programs listed as "For the trinket" No Luck
Does the Adafruit_Servo also require code to run an interrupt?
I think my sketch is pretty simple: check if one of the two binary inputs is on.
Depending on which is on, drive the servo to one of 3 possible positions.
John B.
Central Florida
Trinket servo problems
- Franklin97355
Re: Trinket servo problems
What examples are you running and what error messages are you getting?No Luck
- flsteam
I am running "Blink" copy and pasted into Arduino 1.6.6
I keep getting the error "expected unqualified -id before numeric constant.
- flsteam
I get the same error when compiling "Pulse" also cut and pasted.
IDE 1.6.6 has been quite buggy and puts out a lot of strange compiler errors. We recommend using 1.6.5 for now.
- flsteam
Thanks. I will be back for the servo problems once the compile is solved.
John B.
John B.
- flsteam
Ok, back again....I have installed 1.6.5 and is working fine. Trying to get the servo example going on the trinket. can't get by the following code.
// We'll take advantage of the built in millis() timer that goes off
54.// to keep track of time, and refresh the servo every 20 milliseconds
55.// The SIGNAL(TIMER0_COMPA_vect) function is the interrupt that will be
56.// Called by the microcontroller every 2 milliseconds
57.volatile uint8_t counter = 0;
58.SIGNAL(TIMER0_COMPA_vect) {
59. // this gets called every 2 milliseconds
60. counter += 2;
61. // every 20 milliseconds, refresh the servos!
62. if (counter >= 20) {
63. counter = 0;
64. myServo1
John b.
60. counter += 2;
63. counter = 0;
64. myServo1
John b.
What exactly is the problem with it? If there are error messages, please post them.can't get by the following code.
- flsteam
The code:
The first of many errors: Expected unqualified -id before numeric constant
John B.
Pulse
Pulses the internal LED to demonstrate the analogWrite function
This example code is in the public domain.
To upload to your Gemma or Trinket:
1) Select the proper board from the Tools->Board Menu
2) Select USBtinyISP from the Tools->Programmer
3) Plug in the Gemma/Trinket, make sure you see the green LED lit
4) For windows, install the USBtiny drivers
5) Press the button on the Gemma/Trinket - verify you see
the red LED pulse. This means it is ready to receive data
6) Click the upload button above within 10 seconds
int led = 1; // pulse 'digital' pin 1 - AKA the built in red LED
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
for (int i=0; i<256; i++) {
analogWrite(led, i); // PWM the LED from 0 to 255 (max)
delay(5);
for (int i=255; i>=0; i--) {
analogWrite(led, i); // PWM the LED from 255 (max) to 0
delay(5);
John B.
Reason: Added missing code tags and removed line numbers
Please post the full text of the error message. It will tell you the precise line and column numbers where the error was detected.
- flsteam
First I just installed Windows 10 and for some reason I can't always cut/paste. So before I hand write all the messages let me ask a question. What do I need to have in a sketch to drive a standard hobby servo from a Trinket? I know softservo but do I also to use software interrupts?
You just need the Adafruit Software Servo library: https://learn.adafruit.com/trinket-gemm ... ntrol/code
- flsteam
I have it and it is installed and called in the first line.
Here is the code:
The error message is the same as before: Expected unqualified -id before numeric constant @ line 43
#include <Adafruit_SoftServo.h>
27. int SERVO1PIN 0 // Servo control line (orange) on Trinket Pin #0
28.
29. int POTPIN 1 // Potentiometer sweep (center) on Trinket Pin #2 (Analog 1)
30.
31. Adafruit_SoftServo myServo1; //create servo objects
32.
33. void setup() {
34. // Set up the interrupt that will refresh the servo for us automagically
35. OCR0A = 0xAF; // any number is OK
36. TIMSK |= _BV(OCIE0A); // Turn on the compare interrupt (below!)
37.
38. myServo1.attach(SERVO1PIN); // Attach the servo to pin 0 on Trinket
39. myServo1.write(90); // Tell servo to go to position per quirk
40. delay(15); // Wait 15ms for the servo to reach the position
41.
43. void loop()
44. int potValue; // variable to read potentiometer
45. int servoPos; // variable to convert voltage on pot to servo position
46. potValue = analogRead(POTPIN); // Read voltage on potentiometer
47. servoPos = map(potValue, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
48. analogWrite(myServo1, servoPos); // tell servo to go to position
50. delay(15); // waits 15ms for the servo to reach the position
Here is the code:
28.
30.
32.
33. void setup() {
37.
41.
43. void loop()
Where are those line numbers coming from? Why do they start at 27? The code you posted earlier is only 35 lines long.
- Franklin97355
You can turn off the line numbers in the preferences and then use our
button </> when pasting your code.
