USBtinyISP Programmer Problems
USB AVR Programmer and SPI interface. Adafruit's USBtinyISP.
marke3
Post by marke3 »
My environment is Win 10 on 64bit Core i5 and I have flashed Trinkets via Arduino IDE and AVRs via Avrdude quite happily. I use:
adafruit-arduino-1.6.4-windows\arduino-1.6.4\hardware\tools\avr/bin/avrdude (avrdude: Version 6.0.1)
and:
avrdude version 6.1-svn-20131205, URL: <http://savannah.nongnu.org/projects/avrdude/
Coming back to Trinket over the last week or so something unusual was happening during upload. There are a lot of (70 odd) 'n retries during SPI command' messages on the console during the write. But it flashes successfully so I wasn't too perturbed.
However, the last couple of days I've been unable to flash an AVR as Avrdude is seeing (or not seeing) the USBtinyISP programmer per the following.
C:\Users\Mark\Documents\AVR-Programming-master\Chapter12_Analog-to-Digital-Conversion-II\voltmeter>make flash
avrdude -c usbtiny -p atmega168 -U flash:w:voltmeter.hex
this check.
avrdude done. Thank you.
make: *** [flash] Error 1
Also what seems to have changed is that the devices now show up as USBtiny under Atmel USB Devices in Device Manager.
I've used 3 different USB cables and different Trinkets 3V/5V and get the same outcome.
I've also used 3 different USB cables on the USBtinyISP; via 2.0 hub and 2.0 on laptop; and tried other makefiles that have always worked.
I have retried reinstalling the latest drivers and while the Win 10 exercise never gives me 100% confidence, the right drivers seem to be in the right directories.
I have also searched the forums for anything similar but only been able to find the drivers advice. Any ideas what else I might try?
adafruit_support_rick
Re: USBtinyISP Programmer Problems
Post by adafruit_support_rick »
why are you using an atmega168 processor type for a Trinket?
The rc=-1 error means that the USBtinyISP is not communicating with the target. Do you have anything connected to pins 3 or 4 on the Trinket?
marke3
Post by marke3 »
That is the error when I use the USBtinyISP programmer to (try to) flash a bare 168 AVR. So the three symptoms I'm getting that seem to point towards driver issues are:
In device manager the trinket and the programmer show as USBtiny under Atmel USB Devices.
Flashing a trinket with ID and bootloader works but only after multiple SPI messages during write.
Using the programmer to flash a bare AVR is not working as Avrdude is not seeing the programmer.
marke3
Post by marke3 »
Aha. You mentioned the rc=-1 is problem between programmer and target so I rewired the breadboard and it worked properly. (That probably should have been one of my first debug actions... oops)
I'll just ignore the other non-terminal symptoms :)
Thanks very much, Rick.
OK - good find!
Return to “USBtinyISP”
