FLORA + Microsd
- Seryogaberkut
FLORA + Microsd
Hii! I am using Flora Kit with gps and i need to save data on Micro Sd https://www.adafruit.com/products/254. I got the info from the forum, that I can connect via icsp. Could u please tell me how i can connect Micro Sd with Flora (whith Flora pins). Can I use for that code from this tutorial https://learn.adafruit.com/adafruit-mic ... ial/wiring without changes?
- adafruit_support_rick
Re: FLORA + Microsd
The ICSP pinout is as follows: There's a white dot on the Flora to indicate pin 1
CLK -> SCK
DI -> MOSI
DO-> MISO
CS-> Flora pin D10, or any other free Flora pin. Update the sketch with the pin you choose for CS
5V->Flora 3.3V (it's OK)
GND->GND
Wire as follows:CLK -> SCK
DI -> MOSI
DO-> MISO
GND->GND
