First off, thank you very much for the lessons. They've helped me get from 0 -> "Whoo hoo!" in just a few nights.
One problem I've encountered after the end of lesson 5, is that sometimes pressing the button doesn't register a change. Looking at the code, it appears that this is due to a race condition of pressing the button while the Arduino is performing it's flashing sequence.
Is there a way of performing an asynchronous input loop? Or must everything be done serially?
Thanks,
-Tommy.
Lesson 5 - Input Lockout/Async loop?
- adafruit_support_bill
Re: Lesson 5 - Input Lockout/Async loop?
You can use the AttachInterrupt function to attach an interrupt handler to one of the interrupt pins:
http://arduino.cc/en/Reference/AttachInterrupt
it's less arduinish, but you can also snag one of the timer interrupts. all three timers start up when the arduino starts and they each overflow about once every millisecond. the timer0 overflow is used for the millis function, but the timer1 and timer2 overflows are there for the asking.
