I just received a new Uno and PWM doesn't work on pins 9 and 10 only. PWM is working fine on all other PWM outputs. Pins 9 and 10 work fine as digital outputs. Could this be a bad board, or am I missing something?
When I use the default fade sketch with pin 9, or 10 as the PWM output I get nothing from the LED.
When I used pins 3, 5, 6 or 11 in the same sketch the LED fades as expected.
Has anybody seen this before? Any help with this would be greatly appreciated.
PWM doesn't work on pins 9 and 10 of my new Uno
- grysemonky
- westfw
Re: PWM doesn't work on pins 9 and 10 of my new Uno
Upgrade to 0021 instead of 0020...
The new bootloader changes some timer configuration of the timer that runs PWM on pins 20 and 21 to a state other than that assumed by the Arduino core software. 0021 provides a fix to properly initialize the timer anyway.
- grysemonky
SWEET! Thank you. I'm not really sure how (spelled: I'm a noob), but that did the trick. Thank you for the quick reply. I owe you a milkshake.
