Lesson 6 Question - 1K Potentiometer
For makers who have purchased an Adafruit Starter Pack, get help with the tutorials here!
zelthian
Post by zelthian »
The lesson states you should use a 10K potentiometer (R104) and a 100 ohm resister. In my starter pack, I have a 1K and 100 ohm (R103 and R102) potentiometer.
Can I use the R103 for the tutorial? Do I need to compensate for the difference with a 1k ohm resister?
Re: Lesson 6 Question - 1K Potentiometer
You can use the 1K pot and the 100K resistor. The LED won't dim quite as much and the answers to the resistance calculations will change.
The 100K resistor will still protect the LED from getting too much current.
Post by adafruit »
103 is 10K
zelthian
Post by zelthian »
Interesting... the tutorial states:
http://www.ladyada.net/learn/arduino/LEDs.html wrote:Use a 10K potentiometer for this excersise, find one that has 104 printed on it (this is the same as 1.0 (first two digits) with 4 zeros afterwards = 10,000)
Does the tutorial need to be corrected?
Post by adafruit »
yes 103 is 10K
Return to “Arduino Starter Pack”
