The lesson states you should use a 10K potentiometer (R104) and a 100 ohm resister. In my starter pack, I have a 1K and 100 ohm (R103 and R102) potentiometer.
Can I use the R103 for the tutorial? Do I need to compensate for the difference with a 1k ohm resister?
Lesson 6 Question - 1K Potentiometer
Re: Lesson 6 Question - 1K Potentiometer
You can use the 1K pot and the 100K resistor. The LED won't dim quite as much and the answers to the resistance calculations will change.
The 100K resistor will still protect the LED from getting too much current.
103 is 10K
- zelthian
Interesting... the tutorial states:
Does the tutorial need to be corrected?http://www.ladyada.net/learn/arduino/LEDs.html wrote:Use a 10K potentiometer for this excersise, find one that has 104 printed on it (this is the same as 1.0 (first two digits) with 4 zeros afterwards = 10,000)
yes 103 is 10K
