Arduino Uno - Device Not Recognized
by r0b0nd7 on Fri Mar 18, 2011 12:03 pm
Recently I purchased the "Starter Pack for Arduino (Arduino Uno included)". Today, I tried plugging in my Arduino to my computer as usual and my PC responded with "USB Device Not Recognized". I've tried uninstalling and updating the drivers to no avail. After further researching the problem, it seems that others have been plagued with the same exact issue, and the only solution seems to be replacing the board. I would like to know if there is anything I can do on my side to fix this problem. I purchased the Arduino for a time-critical project and cannot have any further delays.
Thank you in advance,
Rob
r0b0nd7
Re: Arduino Uno - Device Not Recognized
by adafruit_support_bill on Sat Mar 19, 2011 7:23 am
Just to be sure it is the same problem, find the driver install log: C:\Windows\inf\setupapi.dev.log.
Look for the record of your device install (the entries will be time-stamped).
If it says:
{DIF_UPDATEDRIVER_UI} 16:36:42.599
dvi: No class installer for 'Unknown Device'
it is the same problem.
If it says:
dvi:      No class installer for 'Arduino Uno'
the problem is something else.
by r0b0nd7 on Sat Mar 19, 2011 9:55 am
It seems like the arduino is labeled as an unknown device, but just in case I missed something, here is the portion of the file that corresponds to yesterday.
>>>  [Device Install (Hardware initiated) - USB\VID_0000&PID_0000\5&c19c4f&0&2]
>>>  Section start 2011/03/18 11:31:20.650
     ump: Creating Install Process: DrvInst.exe 11:31:20.651
     ndv: Retrieving device info...
     ndv: Setting device parameters...
     ndv: Building driver list...
     dvi: {Build Driver List} 11:31:20.702
     dvi:      Searching for hardware ID(s):
     dvi:           usb\unknown
     dvi:      Searching for compatible ID(s):
     dvi:           usb\unknown
     dvi:      Enumerating INFs from path list 'C:\Windows\INF'
     inf:      Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\usb.inf_98a6b4ed\usb.inf' ([strings.0409] <src=drvstore>)
     dvi:      Created Driver Node:
     dvi:           HardwareID   - USB\UNKNOWN
     dvi:           InfName      - C:\Windows\System32\DriverStore\FileRepository\usb.inf_98a6b4ed\usb.inf
     dvi:           DevDesc      - Unknown Device
     dvi:           DrvDesc      - Unknown Device
     dvi:           Provider     - Microsoft
     dvi:           Mfg          - (Standard USB Host Controller)
     dvi:           ModelsSec    - Generic.Section.NTx86
     dvi:           InstallSec   - BADDEVICE.Dev
     dvi:           ActualSec    - BADDEVICE.Dev.NT
     dvi:           Rank         - 0x0dff0000
     dvi:           Signer       - microsoft windows
     dvi:           Signer Score - INBOX
     dvi:           DrvDate      - 06/21/2006
     dvi:           Version      - 6.0.6001.18000
     inf:      Searched 1 potential matches in published INF directory
     inf:      Searched 46 INFs in directory: 'C:\Windows\INF'
     dvi: {Build Driver List - exit(0x00000000)} 11:31:20.825
     ndv: Selecting best match...
     dvi: {DIF_SELECTBESTCOMPATDRV} 11:31:20.825
     dvi:      No class installer for 'Universal Serial Bus controllers'
     dvi:      No CoInstallers found
     dvi:      Default installer: Enter 11:31:20.832
     dvi:           {Select Best Driver}
     dvi:                Selected driver installs from section [BADDEVICE.Dev] in 'c:\windows\system32\driverstore\filerepository\usb.inf_98a6b4ed\usb.inf'.
     dvi:                Class GUID of device changed to: {36fc9e60-c465-11cf-8056-444553540000}.
     dvi:                Set selected driver complete.
     dvi:                Selected:
     dvi:                     Description - [Unknown Device]
     dvi:                     InfFile     - [c:\windows\system32\driverstore\filerepository\usb.inf_98a6b4ed\usb.inf]
     dvi:                     Section     - [BADDEVICE.Dev]
     dvi:                     Signer      - [microsoft windows]
     dvi:                     Rank        - [0x0dff0000]
     dvi:           {Select Best Driver - exit(0x00000000)}
     dvi:      Default installer: Exit
     dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 11:31:20.835
     ndv: Driver selected, now performing install...
     ndv: {Core Device Install}
     inf:      Opened PNF: 'C:\Windows\INF\usb.inf' ([strings.0409] <src=drvstore>)
     dvi:      {DIF_ALLOW_INSTALL} 11:31:20.898
     dvi:           Default installer: Enter 11:31:20.900
     dvi:      {DIF_ALLOW_INSTALL - exit(0xe000020e)} 11:31:20.900
     ndv:      Installing files...
     dvi:      {DIF_INSTALLDEVICEFILES} 11:31:20.901
     dvi:           Default installer: Enter 11:31:20.902
     dvi:                {Install FILES}
     inf:                     Opened PNF: 'c:\windows\system32\driverstore\filerepository\usb.inf_98a6b4ed\usb.inf' ([strings.0409] <src=drvstore>)
     inf:                     {Install Inf Section [BADDEVICE.Dev.NT]}
     inf:                          CopyFiles=BADDEVICE.CopyFiles  (usb.inf line 102)
!    inf:                          Empty Section! [BADDEVICE.CopyFiles]
     inf:                          No (Copy/Ren/Del)Files directives found
     inf:                     {Install Inf Section [BADDEVICE.Dev.NT] exit (0x00000000)}
     dvi:                     Processing co-installer registration section [BADDEVICE.Dev.NT.CoInstallers].
     inf:                     {Install Inf Section [BADDEVICE.Dev.NT.CoInstallers]}
     inf:                     {Install Inf Section [BADDEVICE.Dev.NT.CoInstallers] exit (0x00000000)}
     dvi:                     Co-installers registered.
     dvi:                     {Install INTERFACES}
     dvi:                          Installing section [BADDEVICE.Dev.NT.Interfaces]
     dvi:                     {Install INTERFACES exit 00000000}
     dvi:                {Install FILES exit (0x00000000)}
     dvi:      {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 11:31:20.907
     ndv:      Pruning file queue...
     dvi:      {_SCAN_FILE_QUEUE}
     flq:           ScanQ flags=620
     flq:                SPQ_SCAN_PRUNE_COPY_QUEUE
     flq:                SPQ_SCAN_FILE_COMPARISON
     flq:                SPQ_SCAN_ACTIVATE_DRP
     flq:           ScanQ number of copy nodes=0
     flq:           ScanQ action=200 DoPruning=32
     flq:           ScanQ end Validity flags=620 CopyNodes=0
     dvi:      {_SCAN_FILE_QUEUE exit(0, 0x00000000)}
     ndv:      Committing file queue...
     flq:      {_COMMIT_FILE_QUEUE}
     flq:           CommitQ DelNodes=0 RenNodes=0 BackNodes=0 CopyNodes=0
     flq:      {_COMMIT_FILE_QUEUE exit(0x00000000)}
     ndv:      Registering CoInstallers...
     dvi:      {DIF_REGISTER_COINSTALLERS} 11:31:20.912
     dvi:           Default installer: Enter 11:31:20.914
     dvi:      {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 11:31:20.917
     ndv:      Installing interfaces...
     dvi:      {DIF_INSTALLINTERFACES} 11:31:20.918
     dvi:           Default installer: Enter 11:31:20.919
     dvi:      {DIF_INSTALLINTERFACES - exit(0x00000000)} 11:31:20.921
     ndv:      Installing device...
     dvi:      {DIF_INSTALLDEVICE} 11:31:20.922
     dvi:           Default installer: Enter 11:31:20.922
     dvi:                {Install DEVICE}
     dvi:                     Processing Registry/Property directives...
     inf:                          AddReg=BADDEVICE.AddReg  (usb.inf line 101)
     inf:                     {Install Inf Section [BADDEVICE.Dev.NT.Hw]}
     inf:                          Empty section
     inf:                     {Install Inf Section [BADDEVICE.Dev.NT.Hw] exit (0x00000000)}
     dvi:                     {Writing Device Properties}
     dvi:                          Provider name=Microsoft
     dvi:                          DriverDate 06/21/2006
     dvi:                          DriverVersion=6.0.6001.18000
     dvi:                          Class name=USB
     dvi:                          Manufacturer=(Standard USB Host Controller)
     dvi:                          Matching DeviceID=usb\unknown
     dvi:                          Strong Name=usb.inf:Generic.Section.NTx86:BADDEVICE.Dev:6.0.6001.18000:usb\unknown
     dvi:                     {Writing Device Properties - Complete}
     inf:                     {Install Inf Section [BADDEVICE.Dev.NT.Services]}
     inf:                          AddService=,0x00000002  (usb.inf line 109)
!    dvi:                          Add Service: NULL Controlling service.
     inf:                     {Install Inf Section [BADDEVICE.Dev.NT.Services] exit(0x00000000)}
     dvi:                {Install DEVICE exit (0x00000000)}
     dvi:                Writing common driver property settings.
     dvi:                     DriverDescription=Unknown Device
     dvi:                     DeviceDisplayName=Unknown Device
     dvi:                Install Device: Restarting device. 11:31:20.949
     dvi:                Install Device: Restarting device completed. 11:31:21.321
     dvi:      {DIF_INSTALLDEVICE - exit(0x00000000)} 11:31:21.322
     dvi:      {Build Driver List} 11:31:21.323
!    dvi:           Driver list already built
     dvi:      {Build Driver List - exit(0x00000000)} 11:31:21.324
     dvi:      {DIF_SELECTBESTCOMPATDRV} 11:31:21.324
     dvi:           Default installer: Enter 11:31:21.330
     dvi:                     Class GUID of device remains: {36fc9e60-c465-11cf-8056-444553540000}.
     dvi:                     Selected:
     dvi:      {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 11:31:21.335
     dvi:      {DIF_NEWDEVICEWIZARD_FINISHINSTALL} 11:31:21.335
     dvi:           Default installer: Enter 11:31:21.335
     dvi:      {DIF_NEWDEVICEWIZARD_FINISHINSTALL - exit(0xe000020e)} 11:31:21.336
     ndv:      Device install status=0x00000000
     ndv:      Performing device install final cleanup...
     ndv: {Core Device Install - exit(0x00000000)}
     ump: Server install process exited with code 0x00000000 11:31:21.341
<<<  Section end 2011/03/18 11:31:21.342
<<<  [Exit status: SUCCESS]
>>>  [Device Install (DiShowUpdateDevice) - USB\VID_0000&PID_0000\5&C19C4F&0&2]
>>>  Section start 2011/03/18 11:46:48.872
      cmd: "C:\Windows\system32\mmc.exe" "C:\Windows\System32\devmgmt.msc" /S
     dvi: {DIF_UPDATEDRIVER_UI} 11:46:48.872
     dvi:      Default installer: Enter 11:46:48.874
     dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 11:46:48.874
     ndv: {Update Driver Software Wizard for USB\VID_0000&PID_0000\5&C19C4F&0&2}
     ndv: {Update Driver Software Wizard exit(00000000)}
<<<  Section end 2011/03/18 11:47:06.043
What causes this to happen? Is the ATMega8U2 malfunctioning?
r0b0nd7
by adafruit_support_bill on Sat Mar 19, 2011 10:45 am
OK. That looks like it.
Please contact support@adafruit.com for a replacement and reference this thread in your message.
by r0b0nd7 on Sat Mar 19, 2011 5:46 pm
Alright, thank you.
Is there anything I can do to prevent this error from occurring?
r0b0nd7
by adafruit_support_bill on Sat Mar 19, 2011 7:40 pm
Most likely the 8U2 programming was not successful. Adafruit will refer this to the Arduino team to help improve the manufacturing process.
by adafruit on Mon Mar 21, 2011 1:40 pm
we're in communication with the team and they are investigating!
by freiguy1 on Thu Oct 13, 2011 11:40 am
I manually reprogrammed the 8U2 using the USBtinyISP.
Also, I blogged about here:
http://blog.ethanfrei.com/2011/10/arduino-uno-revived.html
Check it out!
freiguy1
by micronic on Wed Mar 14, 2012 12:41 pm
My new Uno board doesn't come up, even after swapping in a SECOND ATMEGA328-P module that I purchased from Adafruit just "in case."
The problem appears to be another case of the ATMEGA328 module not being programmed, per other forum entries.
Below are my symptoms. Please advise if it could be something I'm doing wrong.
1. This is what setupapi.dev.log reports (No class installer for 'Unknown driver software package')
>>> [Device Install (DiShowUpdateDevice) - USB\VID_2341&PID_0043\7493430303035121F041]
>>> Section start 2012/03/14 12:09:35.455
cmd: "C:\Windows\system32\mmc.exe" C:\Windows\system32\devmgmt.msc
dvi: {DIF_UPDATEDRIVER_UI} 12:09:35.460
dvi: No class installer for 'Unknown driver software package'
dvi: Default installer: Enter 12:09:35.469
dvi: {DIF_UPDATEDRIVER_UI - exit(0xe000020e)} 12:09:35.480
ndv: {Update Driver Software Wizard for USB\VID_2341&PID_0043\7493430303035121F041}
<<< Section end 2012/03/14 12:09:48.600
2. The Arduino software (Arduino.exe) has the "Tools/Serial Port" item dimmed, indicating it didn't find the module.
Thanks in advance...
micronic
by adafruit_support_bill on Wed Mar 14, 2012 1:06 pm
Windows does not ship with an UNO driver. You have to update the driver software manually.
Plug in your UNO, then check in Device Manager and look for it in "COM & LPT Ports" or "Other Devices". If it is there, you can update the driver software as described here: http://arduino.cc/it/Guide/Windows
by yetiman on Mon Mar 19, 2012 10:20 pm
I had the same problem but found a solution. Go to the 'unknown device' in device manager. Open it's properties and select 'update driver'. Choose to browse for it, then select installed driver, then 'have disk'. Browse for the arduino installation directory and choose the 'arduino UNO.inf' driver in the drivers folder. Click through the rest of the promts and usual warnings about unsigned drivers. Voila.
yetiman
by JRob on Wed Aug 22, 2012 6:36 pm
Mine was basically the same, my Arduino Uno worked fine with my old computer using Windows Vista 32-bit, but on my new laptop using either Windows 7 64-bit or Ubuntu 12.04 64-bit. The problem is though I can't even manually install the driver software like I did before because it is not showing up in the device manager on either OS.
JRob
by adafruit_support_rick on Wed Aug 22, 2012 7:55 pm
@JRob -
Nothing changes anyplace in the device manager when you plug in/unplug the UNO? Try a different cable, try a different USB port, try a powered hub, etc. There have been reports of problems with USB3.0 ports, as well.
by amazonforce20 on Thu Feb 20, 2014 11:19 pm
I hope its okay to resurrect threads. I am having a similar issue. My main problem is that Arduino Micro does not appear ANYWHERE in the device manager. I obviously checked in Ports (COM) AND Other Devices (which doesnt even appear). It seems to be a driver related issue. I have uninstalled and re-installed arduino IDE 1.0.5 a few times and still cant get it to work. I have tried other computer and all usb ports on my pc tower.
Is there anything else I can try?
I appreciate the help.
Here is setupapi.dev data
[Boot Session: 2014/01/26 21:57:06.493]
>>>  [Setup Import Driver Package - c:\program files (x86)\arduino\drivers\arduino.inf]
>>>  Section start 2014/01/30 17:42:54.240
      cmd: "C:\Program Files (x86)\Arduino\drivers\dpinst-amd64.exe" /lm /sw /sa
     inf: Provider: Arduino LLC (www.arduino.cc)
     inf: Class GUID: {4D36E978-E325-11CE-BFC1-08002BE10318}
     inf: Driver Version: 01/04/2013,1.0.0.0
     inf: Catalog File: arduino.cat
     sto: {Copy Driver Package: c:\program files (x86)\arduino\drivers\arduino.inf} 17:42:54.253
     sto:      Driver Package = c:\program files (x86)\arduino\drivers\arduino.inf
     sto:      Flags          = 0x00000007
     sto:      Destination    = C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}
     sto:      Copying driver package files to 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}'.
     flq:      Copying 'c:\program files (x86)\arduino\drivers\arduino.cat' to 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.cat'.
     flq:      Copying 'c:\program files (x86)\arduino\drivers\arduino.inf' to 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.inf'.
     sto: {Copy Driver Package: exit(0x00000000)} 17:42:54.299
     pol: {Driver package policy check} 17:42:54.546
     pol: {Driver package policy check - exit(0x00000000)} 17:42:54.547
     sto: {Stage Driver Package: C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.inf} 17:42:54.549
     inf:      {Query Configurability: C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.inf} 17:42:54.625
     inf:           Driver package 'arduino.inf' is configurable.
     inf:      {Query Configurability: exit(0x00000000)} 17:42:54.666
     flq:      Copying 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.cat' to 'C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}\arduino.cat'.
     flq:      Copying 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.inf' to 'C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}\arduino.inf'.
     sto:      {DRIVERSTORE IMPORT VALIDATE} 17:42:54.672
     sig:           {_VERIFY_FILE_SIGNATURE} 17:42:54.681
     sig:                Key      = arduino.inf
     sig:                FilePath = C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}\arduino.inf
     sig:                Catalog  = C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}\arduino.cat
!    sig:                Verifying file against specific (valid) catalog failed! (0x800b0109)
!    sig:                Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider.
     sig:           {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 17:42:54.698
     sig:           {_VERIFY_FILE_SIGNATURE} 17:42:54.698
     sig:                Success: File is signed in Authenticode(tm) catalog.
     sig:                Error 0xe0000242: The publisher of an Authenticode(tm) signed catalog has not yet been established as trusted.
     sig:           {_VERIFY_FILE_SIGNATURE exit(0xe0000242)} 17:42:54.713
!    sig:           Driver package signer is unknown, but user trusts signer.
     sig:           Driver package certificate was successfully installed.
     sto:      {DRIVERSTORE IMPORT VALIDATE: exit(0x00000000)} 17:42:57.646
     sig:      Signer Score = 0x0F000000
     sig:      Signer Name  = Arduino LLC
     sto:      {DRIVERSTORE IMPORT BEGIN} 17:42:57.647
     sto:      {DRIVERSTORE IMPORT BEGIN: exit(0x00000000)} 17:42:57.647
     cpy:      {Copy Directory: C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}} 17:42:57.647
     cpy:           Target Path = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe
     cpy:      {Copy Directory: exit(0x00000000)} 17:42:57.648
     idb:      {Register Driver Package: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf} 17:42:57.652
     idb:           Created driver package object 'arduino.inf_amd64_844213a156728dfe' in SYSTEM database node.
     idb:           Created driver INF file object 'oem22.inf' in SYSTEM database node.
     idb:           Registered driver package 'arduino.inf_amd64_844213a156728dfe' with 'oem22.inf'.
     idb:      {Register Driver Package: exit(0x00000000)} 17:42:57.655
     idb:      {Publish Driver Package: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf} 17:42:57.655
     idb:           Activating driver package 'arduino.inf_amd64_844213a156728dfe'.
     cpy:           Published 'arduino.inf_amd64_844213a156728dfe\arduino.inf' to 'oem22.inf'.
     idb:           Indexed 25 device IDs for 'arduino.inf_amd64_844213a156728dfe'.
     idb:      {Publish Driver Package: exit(0x00000000)} 17:42:57.659
     sto:      {DRIVERSTORE IMPORT END} 17:42:57.660
     sig:           Installed catalog 'arduino.cat' as 'oem22.cat'.
     sto:      {DRIVERSTORE IMPORT END: exit(0x00000000)} 17:42:57.701
     sto: {Stage Driver Package: exit(0x00000000)} 17:42:57.702
<<<  Section end 2014/01/30 17:42:57.708
>>>  [SetupCopyOEMInf - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf]
>>>  Section start 2014/01/30 17:42:57.715
     inf: Driver Store Path: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf
     inf: Published Inf Path: C:\Windows\INF\oem22.inf
     sig: Installing catalog arduino.cat as: oem22.CAT
<<<  Section end 2014/01/30 17:42:57.817
amazonforce20
by amazonforce20 on Thu Feb 20, 2014 11:26 pm
I forgot to mention that the light is pulsing at first and then flashing 3 blinks in a row and then a pause. blink-blink-blink-largedelay-blink-blink-blink
amazonforce20
