Arduino Uno - Device Not Recognized
Re: Arduino Uno - Device Not Recognized
by adafruit_support_rick on Wed Aug 22, 2012 7:55 pm
@JRob -
Nothing changes anyplace in the device manager when you plug in/unplug the UNO? Try a different cable, try a different USB port, try a powered hub, etc. There have been reports of problems with USB3.0 ports, as well.
by amazonforce20 on Thu Feb 20, 2014 11:19 pm
I hope its okay to resurrect threads. I am having a similar issue. My main problem is that Arduino Micro does not appear ANYWHERE in the device manager. I obviously checked in Ports (COM) AND Other Devices (which doesnt even appear). It seems to be a driver related issue. I have uninstalled and re-installed arduino IDE 1.0.5 a few times and still cant get it to work. I have tried other computer and all usb ports on my pc tower.
Is there anything else I can try?
I appreciate the help.
Here is setupapi.dev data
[Boot Session: 2014/01/26 21:57:06.493]
>>>  [Setup Import Driver Package - c:\program files (x86)\arduino\drivers\arduino.inf]
>>>  Section start 2014/01/30 17:42:54.240
      cmd: "C:\Program Files (x86)\Arduino\drivers\dpinst-amd64.exe" /lm /sw /sa
     inf: Provider: Arduino LLC (www.arduino.cc)
     inf: Class GUID: {4D36E978-E325-11CE-BFC1-08002BE10318}
     inf: Driver Version: 01/04/2013,1.0.0.0
     inf: Catalog File: arduino.cat
     sto: {Copy Driver Package: c:\program files (x86)\arduino\drivers\arduino.inf} 17:42:54.253
     sto:      Driver Package = c:\program files (x86)\arduino\drivers\arduino.inf
     sto:      Flags          = 0x00000007
     sto:      Destination    = C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}
     sto:      Copying driver package files to 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}'.
     flq:      Copying 'c:\program files (x86)\arduino\drivers\arduino.cat' to 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.cat'.
     flq:      Copying 'c:\program files (x86)\arduino\drivers\arduino.inf' to 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.inf'.
     sto: {Copy Driver Package: exit(0x00000000)} 17:42:54.299
     pol: {Driver package policy check} 17:42:54.546
     pol: {Driver package policy check - exit(0x00000000)} 17:42:54.547
     sto: {Stage Driver Package: C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.inf} 17:42:54.549
     inf:      {Query Configurability: C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.inf} 17:42:54.625
     inf:           Driver package 'arduino.inf' is configurable.
     inf:      {Query Configurability: exit(0x00000000)} 17:42:54.666
     flq:      Copying 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.cat' to 'C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}\arduino.cat'.
     flq:      Copying 'C:\Users\AMAZO_~1\AppData\Local\Temp\{3a7d212c-76ec-5641-874e-d5615356360a}\arduino.inf' to 'C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}\arduino.inf'.
     sto:      {DRIVERSTORE IMPORT VALIDATE} 17:42:54.672
     sig:           {_VERIFY_FILE_SIGNATURE} 17:42:54.681
     sig:                Key      = arduino.inf
     sig:                FilePath = C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}\arduino.inf
     sig:                Catalog  = C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}\arduino.cat
!    sig:                Verifying file against specific (valid) catalog failed! (0x800b0109)
!    sig:                Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider.
     sig:           {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 17:42:54.698
     sig:           {_VERIFY_FILE_SIGNATURE} 17:42:54.698
     sig:                Success: File is signed in Authenticode(tm) catalog.
     sig:                Error 0xe0000242: The publisher of an Authenticode(tm) signed catalog has not yet been established as trusted.
     sig:           {_VERIFY_FILE_SIGNATURE exit(0xe0000242)} 17:42:54.713
!    sig:           Driver package signer is unknown, but user trusts signer.
     sig:           Driver package certificate was successfully installed.
     sto:      {DRIVERSTORE IMPORT VALIDATE: exit(0x00000000)} 17:42:57.646
     sig:      Signer Score = 0x0F000000
     sig:      Signer Name  = Arduino LLC
     sto:      {DRIVERSTORE IMPORT BEGIN} 17:42:57.647
     sto:      {DRIVERSTORE IMPORT BEGIN: exit(0x00000000)} 17:42:57.647
     cpy:      {Copy Directory: C:\Windows\System32\DriverStore\Temp\{192e38eb-0da7-5e40-91ba-552fdf03ed20}} 17:42:57.647
     cpy:           Target Path = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe
     cpy:      {Copy Directory: exit(0x00000000)} 17:42:57.648
     idb:      {Register Driver Package: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf} 17:42:57.652
     idb:           Created driver package object 'arduino.inf_amd64_844213a156728dfe' in SYSTEM database node.
     idb:           Created driver INF file object 'oem22.inf' in SYSTEM database node.
     idb:           Registered driver package 'arduino.inf_amd64_844213a156728dfe' with 'oem22.inf'.
     idb:      {Register Driver Package: exit(0x00000000)} 17:42:57.655
     idb:      {Publish Driver Package: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf} 17:42:57.655
     idb:           Activating driver package 'arduino.inf_amd64_844213a156728dfe'.
     cpy:           Published 'arduino.inf_amd64_844213a156728dfe\arduino.inf' to 'oem22.inf'.
     idb:           Indexed 25 device IDs for 'arduino.inf_amd64_844213a156728dfe'.
     idb:      {Publish Driver Package: exit(0x00000000)} 17:42:57.659
     sto:      {DRIVERSTORE IMPORT END} 17:42:57.660
     sig:           Installed catalog 'arduino.cat' as 'oem22.cat'.
     sto:      {DRIVERSTORE IMPORT END: exit(0x00000000)} 17:42:57.701
     sto: {Stage Driver Package: exit(0x00000000)} 17:42:57.702
<<<  Section end 2014/01/30 17:42:57.708
<<<  [Exit status: SUCCESS]
>>>  [SetupCopyOEMInf - C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf]
>>>  Section start 2014/01/30 17:42:57.715
     inf: Driver Store Path: C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_844213a156728dfe\arduino.inf
     inf: Published Inf Path: C:\Windows\INF\oem22.inf
     sig: Installing catalog arduino.cat as: oem22.CAT
<<<  Section end 2014/01/30 17:42:57.817
amazonforce20
by amazonforce20 on Thu Feb 20, 2014 11:26 pm
I forgot to mention that the light is pulsing at first and then flashing 3 blinks in a row and then a pause. blink-blink-blink-largedelay-blink-blink-blink
amazonforce20
by adafruit_support_bill on Fri Feb 21, 2014 7:19 am
If it were a driver problem, it should at least show up as an unknown device.
So the 32U4 processor is running the bootloader. Since it also implements the USB communication, it should be visible as a device. Try a different cable and/or USB port.
by amazonforce20 on Fri Feb 21, 2014 11:16 am
Bill,
Thank you so much. That was exactly my problem. I was attempting to communicate with a "charge only" usb cable. I used a different usb cable and it worked perfectly.
Sorry for such a newbie question. I was freaking out for a second there. I'm a ME major trying to learn some electronics controls. Wish me luck!
Thanks again!
amazonforce20
by adafruit_support_rick on Fri Feb 21, 2014 12:12 pm
Have you tried a different USB cable? Also, if you have a self-powered hub, try attaching through that. If it still doesn't show up, we can replace the Micro. Please email support@adafruit.com with a link to this thread to arrange a replacement Micro.
