Arduino Telegraph
For makers who have purchased an Adafruit Starter Pack, get help with the tutorials here!
greenleaf
Arduino Telegraph
Post by greenleaf »
Here's a short program that turns your Arudino into a simple telegraph key. It outputs dots and dashes to the serial port while simultaneously lighting up the LED on pin 13. Now you can print "Hello world" like it's 1939!
#include <Bounce.h>
#define BUTTON 2
#define LED 13
Arduino Telegraph Key - turns your Arduino into a simple morse-code device.
Pressing the button will transmit dits and dahs to the serial port, while
lighting up the LED plugged into pin 13 (or on-board LED).
The Bounce library is required for this program to work:
http://www.arduino.cc/playground/Code/Bounce
You may do whatever you like with this code!
// First set up our bounce instance, with a 20ms delay
Bounce bouncer = Bounce(BUTTON,20);
// Define variables for clicks and pauses
int clickDuration;
int pauseDuration;
  pinMode(BUTTON, INPUT);
  pinMode(LED, OUTPUT);
  Serial.begin(9600);
  // Update the bouncer
  bouncer.update();
  int buttonState = bouncer.read();
  clickDuration = 0;
  pauseDuration = 0;
  while (buttonState == HIGH) {
    // Measure how long the button is pressed
    digitalWrite(LED, HIGH);
    clickDuration++;
    delay(1);
    bouncer.update();
  if (clickDuration > 0 && clickDuration < 200) {
    Serial.print(".");                // Print a 'dit' for presses less than 200ms
  } else if (clickDuration > 200) {
    Serial.print("-");                // Print a 'dah' for presses more than 200ms
  while (buttonState == LOW) {
    // Measure the pause between presses
    digitalWrite(LED, LOW);
    pauseDuration++;
    delay(1);
    bouncer.update();
  if (pauseDuration > 1000) {
    Serial.print(" ");                // Print a space for pauses greater than 1 second
  if (pauseDuration > 3000) {
    Serial.print("/ ");               // Print a / for pauses greater than 3 seconds
Return to “Arduino Starter Pack”
