I purchased a Starter Pack for Arduino, down loaded (arduino-0022) and extrated all files. Hooked up usb cord and have try to many times to down load driver, with NO results. I down loaded cdm 20814_WHQL_Certified and try to down load it with out any luck. I do have power to the board.
Help Help
Dan
Can not down load driver
Re: Can not down load driver
I'm assuming you've followed the following link exactly:
http://arduino.cc/en/Guide/Windows
What OS are you running? Do you have any other USB devices plugged in while you try and install the drivers?
Yes, follow it up to the point I am not getting "Arduino UNO (COMxx)"
What version of Windows are you running?
Did your system recognize that a device had been connected? (any sound or popup)
Do you see any LED activity on the UNO?
I am running Windows XP with serice pack 3, yes I have a window pop up asking do I want to find driver automatic or do I want to Pick, I have check I will pick and followeed instructions. On the board I have power on LED lit.
Dan
Dan
When picking the driver location, did you select "Arduino-0022/drivers" or "Arduino-0022/drivers/FTDI USB drivers"?
The UNO drivers are in the first location.
Did the Hardware Update Wizard give you any error popups? Or did it indicate a successful install as below:
Iam Bad, I was using second location, used first and it is now loaded and I have run my first sketch
Thank you
Dan
Thank you
Dan
