(Solved)Uno R3 Driver not detected when manually choosing top level folder
Re: (Solved)Uno R3 Driver not detected when manually choosing top level folder
by adafruit_support_bill on Fri Dec 09, 2011 7:02 am
The FTDI drivers were used for older versions of the Arduino. The UNO's don't use the FTDI chip and instead use the drivers in the Arduino distribution.
by rbwilliams on Wed Dec 28, 2011 4:04 pm
Hello, if you have not already solved your problem, you could try my method. It worked for me!
http://riverembedded.hackhut.com/2011/1 ... wn-device/
Roger
rbwilliams
by Calibos on Sat Jan 14, 2012 7:30 pm
I had fits trying to get the Arduino driver to load on my XP Pro laptop. I wrote Jeremy Blum, and he answered in a day or so.He refrenced the page http://arduino.cc/en/Guide/Windows#toc4 , which then gave me the driver file name. For the uno, it is "ArduinoUNO.inf". Once found, I could not get the driver to upload using the driver update manager. I opened the Arduino files and found the file Arduino\Drivers\Arduino MEGA 2560.inf.
I did a drag and drop to the My Documents folder, used the My Documents Folder as the file destination for the hardware driver update Wizard after the selections.. No, not at this time > Install from a list...> Include this location in the search:
C:\Documents and Settings\Owner\My Documents
Bingo it loaded. I hope this helps someone.
Calibos
