fail out of the box
fail out of the box
by ki0g on Fri Feb 01, 2013 1:56 pm
Win7 but does not see the UNO. Unknown device shown in list of devices.
Install Wizard did not launch.
I tried another USB cable with same results and pressed the Reset
ki0g
Re: fail out of the box
by adafruit_support_rick on Fri Feb 01, 2013 4:29 pm
Try right-clicking on the 'unknown device' in Device Manager. Select 'Update Driver'.
That should bring up the Hardware Update Wizard. Follow the same instructions as for the "Found New Hardware Wizard" to install the Windows Driver
Re: fail out of the box but the computer still has not found it.
by ki0g on Fri Feb 01, 2013 5:26 pm
we have a flashing yellow and solid green LED.
ki0g
by adafruit_support_bill on Sat Feb 02, 2013 7:29 am
And can you select it as a COM port in the IDE?
by JD3 on Sat Feb 02, 2013 1:16 pm
This may be some help, from the Arduino website. It's the installation guide :)
http://arduino.cc/en/Guide/Windows
That little black caterpillar you just stepped on will set you back a few bucks....
JD3
