Experimenter's Guide Book RGB Schematic Error
by modeller on Sun Feb 17, 2013 8:07 pm
On page 30, it shows the RGB LED common pin connected to +5V, yet the schematic symbol indicates it's common cathode. Being careful, I set it up and verified the one supplied is common anode. The schematic symbol in the experimenter's book is wrong, which will confuse people who are paying attention. :)
In the book, the schematic symbol is the one on the left, yet it calls for this pin to be connected to +5V. You should use the symbol on the right.
modeller
Re: Experimenter's Guide Book RGB Schematic Error
by adafruit on Sun Feb 17, 2013 8:16 pm
modeller wrote:On page 30, it shows the RGB LED common pin connected to +5V, yet the schematic symbol indicates it's common cathode. Being careful, I set it up and verified the one supplied is common anode. The schematic symbol in the experimenter's book is wrong, which will confuse people who are paying attention. :)
hiya,
which book are you referring to?
thanks,
adafruit support
by modeller on Sun Feb 17, 2013 8:20 pm
adafruit wrote:hiya,
thanks,
adafruit support
The book that comes with the kit below -
Adafruit ARDX - v1.3 Experimentation Kit for Arduino (Uno R3) - v1.3
http://www.adafruit.com/products/170
modeller
by modeller on Mon Feb 18, 2013 8:12 am
Please find attached the scanned page from the printed manual that came with the kit. As you can see, the schematic symbol for the LED is incorrect for the part that was supplied in my kit at least. Because there is no way to know if the symbol is wrong, or the suggested voltage, you have to make sure yourself what the error was.
modeller
by adafruit on Mon Feb 18, 2013 8:34 am
modeller wrote:Please find attached the scanned page from the printed manual that came with the kit. As you can see, the schematic symbol for the LED is incorrect for the part that was supplied in my kit at least. Because there is no way to know if the symbol is wrong, or the suggested voltage, you have to make sure yourself what the error was.
thanks! we'll let the author know (http://oomlout.com/a/products/ardx/).
