circ-02: last led won't light up
I did the circ 02 and downloaded the sketch, but the last Led doesn't light up. i tried troubleshooting the code to the best of my ability, which is not great. I changed leds around and checked the output of pin 9 with a voltmeter after I changed the on time so there was time to check the voltage. no voltage there on pin 9. then I changed the sketch to the simple blink sketch and changed the pin in that sketch to pin 9 and that works o.k. so for some reason pin 9 is not getting the signal. what's up??? thanks
Re: circ-02: last led won't light up
Can you post a link to that please?I did the circ 02 and downloaded the sketch
It tells you in the instructions for circ-02 to go to http://ardx.org/code02.
Post a photo showing all your wiring.
The problem is that I don't know enough about programming and the program or "sketch" that they tell you to download is really confusing to me. I finally made my own program and it all worked as it should so there is nothing wrong with the Arduino or my wiring. In the program I wrote I had to write each line of program out, couldn't use any of the "shortcuts" they showed. This made for a long program and an awkward one, but it worked. for example, after each line that told an led to light, I had to write aline for the time delay and put in the value of time. Of course, this is awkward, because if I wanted to change that value, I would have to change it multiple time. I know there must be a better way, and I tried some things, but just couldn't get the program to compile. so I have to learn more about programming. thanks, Bill
AND, how do you post an image????
To post an image, use the "upload attachment" tab just below the message editing window.
Sounds like you need what is called a 'variable'. For example, in the code below, you can just change "onTime" and "offTime" in one place and it will apply everywhere within the loop():after each line that told an led to light, I had to write aline for the time delay and put in the value of time. Of course, this is awkward, because if I wanted to change that value, I would have to change it multiple time
void loop()
int onTime = 1000;
int offTime = 500;
digitalWrite(2, HIGH); // turn the LED on (HIGH is the voltage level)
delay(onTime ); // wait for a second
digitalWrite(2, LOW); // turn the LED off by making the voltage LOW
delay(offTime ); // wait for a second
digitalWrite(3, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(3, LOW); // turn the LED off by making the voltage LOW
digitalWrite(4, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(4, LOW); // turn the LED off by making the voltage LOW
I tried something like that, but it would not go through. kept giving me a message about the brackets, so obviously I am not doing something correctly. I tried changing the bracket positions, and other things, but could not get it to "compile" (is that the correct word?) I need to learn more about this programming language. It will just take time and study and I will get it. thanks. Bill
You need to make sure that your brackets are balanced. For every '{' you must have a '}'.
A good reference for the Arduino language is here: http://arduino.cc/en/Reference/HomePage
