Breadboard layout
For makers who have purchased an Adafruit Starter Pack, get help with the tutorials here!
ToolGal13
Breadboard layout
Post by ToolGal13 »
I'm a complete newbie when it comes to working with breadboards.
As mentioned in the posts I've just read, the breadboard referenced in Tutorial 2 isn't the same as the one shipped in the Starter pack. That said, one responder mentioned that you could "do point-to-point wiring" or something else to designate a row as being positive or negative. I have no desire to blow out the LED because it isn't wired properly.
Can someone who's worked with the Ting #65 mini breadboard provide some enlightenment?
Franklin97355
Re: Breadboard layout
Post by Franklin97355 »
Here is a layout of a breadboard http://www.paleotechnologist.net/?cat=264 If you have a specific question please feel free to ask.
1chicagodave
Post by 1chicagodave »
Here is the breadboard connections shown in tutorial #2 -
STD Breadboard
STD Breadboard
Most "standard" breadboards have "rails" running along the outside edges (typically used for V+ and GND as seen in diagram above)
The main difference between those and the tiny breadboard is that the tiny does not have those rails....it's essentially just the center part of a normal breadboard.
Using a tiny breadboard, the LED wiring would look more like this -
Tiny Breadboard
Tiny Breadboard
Return to “Arduino Starter Pack”
