The code that I wrote is posted here:
void cycle(){
int delayTime = 1000;
for(int i = 0; i <= sizeof(COLORS); i++){
setColor(ledDigitalOne, COLORS[i]);
delay(delayTime);
for(int i = 7; i >= sizeof(COLORS); i--){
setColor(ledDigitalOne,COLORS[i]);
delay(delayTime);
* | Experimentation Kit for Arduino Example Code |
* | CIRC-RGB .: Colourful Light :. (RGB LED) |
* We've blinked an LED and controlled eight in sequence now it's time to
* control colour. Using an RGB LED (actual 3 LEDs in a single housing)
* we can generate any colour our heart desires.
* (we'll also use a few programming shortcuts to make the code
* more portable/readable)
//RGB LED pins
int ledDigitalOne[] = {9, 10, 11}; //the three digital pins of the digital LED
//9 = redPin, 10 = greenPin, 11 = bluePin
const boolean ON = LOW; //Define on as LOW (this is because we use a common
//Anode RGB LED (common pin is connected to +5 volts)
const boolean OFF = HIGH; //Define off as HIGH
//Predefined Colors
const boolean RED[] = {ON, OFF, OFF};
const boolean GREEN[] = {OFF, ON, OFF};
const boolean BLUE[] = {OFF, OFF, ON};
const boolean YELLOW[] = {ON, ON, OFF};
const boolean CYAN[] = {OFF, ON, ON};
const boolean MAGENTA[] = {ON, OFF, ON};
const boolean WHITE[] = {ON, ON, ON};
//const boolean BLACK[] = {OFF, OFF, OFF};
//An Array that stores the predefined colors (allows us to later randomly display a color)
const boolean* COLORS[] = {RED, GREEN, BLUE, YELLOW, CYAN, MAGENTA, WHITE};
void setup(){
for(int i = 0; i < 3; i++){
pinMode(ledDigitalOne[i], OUTPUT); //Set the three LED pins as outputs
void loop(){
/* Example - 1 Set a color
Set the three LEDs to any predefined color
//setColor(ledDigitalOne, RED); //Set the color of LED one
/* Example - 2 Go through Random Colors
Set the LEDs to a random color
//randomColor();
cycle();
void cycle(){
delay(delayTime);
delay(delayTime);
void randomColor(){
int rand = random(0, sizeof(COLORS) / 2); //get a random number within the range of colors
setColor(ledDigitalOne, COLORS[rand]); //Set the color of led one to a random color
delay(1000);
/* Sets an led to any color
led - a three element array defining the three color pins (led[0] = redPin, led[1] = greenPin, led[2] = bluePin)
color - a three element boolean array (color[0] = red value (LOW = on, HIGH = off), color[1] = green value, color[2] =blue value)
void setColor(int* led, boolean* color){
digitalWrite(led[i], color[i]);
/* A version of setColor that allows for using const boolean colors
void setColor(int* led, const boolean* color){
boolean tempColor[] = {color[0], color[1], color[2]};
setColor(led, tempColor);
