I have Arduino stater Kit and in project book, project 2, Spaceship interface will not work after i type in my sketch and click to verify. I have check for errors in sketch it seems OK, I get the error message " expected unqualified-id before numeric constant"
I don't know what this means. I can get the sketch out of the library and verify and upload and everything works fine. Can someone help me? Thank You
code
Re: code
If it works from the library and not when you type it in, then there must be a typo. Post the code you are having a problem with.
- swan7
Re: code
Here is the sketch i typed in. Thank You
1 int switchState = 0;
2 void setup(){
3 pinMode(3,OUTPUT);
4 pinMode(4,OUTPUT);
5 pinMode(5,OUTPUT);
6 pimMode(2,Input);
7 }
8 void loop(){
9 switchState = digitalRead(2);
10 // this is for comment
11 if (switchState = = LOW) {
12 // the button is not pressed
13 digitalWrite(3, HIGH); // green LED
14 digitalWrite(4, LOW); // red LED
15 digitalWrite(5, LOW); // red LED
16 }
17 else { // the button is pressed
18 digitalWrite(3, LOW);
19 digitalWrite(4, LOW);
20 digitalWrite(5, HIGH);
21 delay(250); //wait for quarter second
22 // toggle the LEDs
23 digitalWrite(4, HIGH);
24 digitalWrite(5, LOW);
25 delay(250); // waitfor a quarter second
26 }
27 } //go back to the beginning of the loop
2 void setup(){
6 pimMode(2,Input);
7 }
8 void loop(){
16 }
26 }
Re: code
You do not need to type in the line numbers. This will only confuse the compiler.
- swan7
Re: code
Thank You Removing the line numbers fixed that problem, but another error pop up " switchState was not declared in this scope." In the book the lines are numbered i did not know not to include them. If you can help me again i would be very Thank full. Which one of your books on programming would be the most helpful ?
Thank you so much
Thank you so much
- Franklin97355
Re: code
Did you fix the problem with the == ? This is a good starter book https://www.adafruit.com/product/1019 There are also 18 lessons on the Arduino by Simon Monk starting here https://learn.adafruit.com/adafruit-ard ... on-1-blink
Re: code
Post your code as it is now. switchState should be defined in the very first line:
- swan7
Re: code
// declare the LED pins as output
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//declare the switch pin as an input
pinMode(2,INput);
// read the value of switch
// digitalRead () checks to see if there is voltage
//on the pin or not
switchstate =digitalRead(2);
// if the button is not pressed
// turn on the green LED and turn off the red LEDs
if (switchState ==LOW) {
//the button is not pressed
digitalWrite(3, HIGH); // turn the green LED on pin 3 on
digitalWrite(4, LOW); // turn the red LED on pin 4 off
digitalWrite(5, LOW); // turn the red LED on pin 5 off
// this else is part of the above if () statement.
// if the switch is not LOW (the button is pressed)
// turn off the green LED and blink BANNED the red LEDs
digitalWrite(3, LOW); // turn the green LED on pin 3 off
digitalWrite(5, HIGH); // turn the red LED on pin5 on
// wait for a quarter second
// toggle the LEDs
digitalWrite(5, LOw);
delay(250); // wait for a quarter second
}//go back to the beginning of the loop
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(2,INput);
//on the pin or not
// toggle the LEDs
Re: code
There were several places where you had capitalization errors. The compiler is very unforgiving with that. "switchstate" is not the same as "switchState".
This should compile for you:
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(2,INPUT);
//on the pin or not
switchState =digitalRead(2);
// toggle the LEDs
- swan7
Re: code
I finely got it to work Thank to You !!!. I will order that programming book as soon as i send this e-mail.
I just want to say Thanks to Adafruit and there dedicated employee who worked with me to get my little sketch working. Now all i have to do is find the barn and the gate to it, to have a new roof put on it. It's like a Jungle out back there, that is what my brother said about my driveway, just think what the back looks like. I want to Thank You again for being so nice.
THANK YOU
Jim Andersen
THANK YOU
Jim Andersen
Re: code
You are welcome. That is what we are here for!
Re: code
@smbyrne4 - I'm not sure I understand the question. Is it about the lesson 6 code or the serial monitor?
Please tell us what you are trying to do.
